Resealing the plastic liners found behind door panels
Old Jul 23, 2016 | 09:38 AM
Paj's Avatar
Paj
the liners sealant is done and to help prevent water from entering the car (still glad im not the only one with leaky doors) im going to reseal the plastic door liners.
1. How do i remove the left over residue so i can ensure new sealant can bond with panel?
2. went to autozone and found this. will this be okay to use?
Permatex/3 oz. tube black silicone adhesive sealant 81158- ReadReviews onPermatex #81158
Old Jul 23, 2016 | 09:59 AM
LarryS's Avatar
Get 3M weather strip sealant you can spread smoothly. I would stay away from anything with "silicone" in the title (or ingredients). Once silicone gets on a surface it is nearly impossible to clean properly for future adhesion, even using high percentage isoprophol alcohol.
Old Jul 23, 2016 | 12:36 PM
Paj's Avatar
Paj
thanks! i used the rubbing alcohol and it did get the residue off completely. I went and bought the 3M black super weatherstrip adhesive
Old Jul 23, 2016 | 02:30 PM
LarryS's Avatar
READ THE DIRECTIONS! Clean both surfaces. Spread lightly on both sides, let dry. Then apply again and press together when tacky. Superior grip when used properly. Works very poorly if assembled wet, as with regular glue. Good luck.
Old Jul 23, 2016 | 03:59 PM
Paj's Avatar
Paj
hmm well the instructions didnt say anything about the 2nd coat so im hoping it doesnt need it.
I did let it dry hopefully it was enough time. it was tacky when i press it together finally but theres always that little voice saying "it could be tackier" so we'll see tomorrow if it work.
It was approx. 24 hours for cure time so i'll grab the water hose and spray it outside the door to see if it'll hold etc tomorrow night.
Old Jul 23, 2016 | 04:21 PM
LarryS's Avatar
I'm sure you will be fine.
Old Jul 23, 2016 | 04:29 PM
LarryS's Avatar
A trick we do with Amphicars is to close the door over a dollar bill. If the doorseal fits properly you cannot pull the bill out of the closed door. If the bill pulls out easily the seal will leak & either the hinge or latch may need adjustment. On occassion the weather stripping itself needs a "shim" to properly seat.
On that vehicle this is a test done with door & body seals that compress together. You won't get as much pull against the bill with the rubber door seal compressing against painted metal.
Old Jul 24, 2016 | 04:29 PM
Paj's Avatar
Paj
So the Right door work fine i dump some water on it and the water that got through the tape stayed inside till it went through the hole at the bottom. the Left side tho the water got through the plastic. I think what happened is that i left just enough crinkle that the adhesive counldnt hold the plastic to the metal. Do i need to buy adhesive removal or can i just peel and add some more adhesive but this time make sure theres no crinkle?
Spacecoast
83
Aug 3, 2017 01:47 PM
Paj
May 12, 2017 02:55 PM
1speedbike
Feb 2, 2016 01:00 PM
4dr4life!
Dec 7, 2014 10:58 PM
SHOELAC3D
Oct 3, 2013 11:22 AM
