sudden drop in power during normal highway drive?
Old Sep 21, 2016 | 10:07 PM
ghostagent's Avatar
So I posted a while ago about the radio power cutting out with A/C on and haven't experienced it since.
today I've noticed that it feels like a split second power drain (on high way) with A/C on. I tried to reproduce the problem with A/C off and wasn't able to. the drive is normal consistent pedal pressure and just feels like it lose some power and slows down.. car did not shift gears. can this be battery as well? or am I looking at bigger issue?
tx
Old Sep 22, 2016 | 09:49 AM
Carbuff2's Avatar
It IS normal for a driver in a four cylinder, marginally powerful car to feel the extra load when the A/C cuts on. At least, that's been my experience over many years of driving.
According to this site,
performance - How much power (HP) do the components on the engine belt generally use? - Motor Vehicle Maintenance & Repair Stack Exchange
you will see ~5 HP for the A/C compressor, and a few more HP due to the alternator's providing current to the compressor clutch, rad fans, and interior fans.
So, I'd estimate that you may see an 8% drop in available power (the Fit is rated at 109 HP).
My more powerful cars don't exhibit this behavior.
Old Sep 22, 2016 | 10:48 AM
ghostagent's Avatar
someone suggested changing the battery.. will that help?
this seems to be more noticeable these days at ~ 100k
good thing fall is coming. I'm considering ditching the car over the winter
Old Sep 22, 2016 | 01:05 PM
Carbuff2's Avatar
Changing the battery won't help with the A/C system requiring more power during operation....
Never hurts to check battery electrolyte levels after a hot summer...perhaps have the battery load tested too. But, don't just throw money at the issue. I'd check for poor connections at the alternator and battery, as I've found that aftermarket battery terminals are too small...they might be loose even though the clamp terminals are small & tight as they can go. <--if that's the case they simply need to be shimmed.
Old Sep 23, 2016 | 02:47 AM
KV43's Avatar
Just a quick thought, I would check to make sure the A/C pulley belt isn't slipping. Kinda hard to tell at highway speeds but try to listen for belt squeaks around town.
Old Sep 23, 2016 | 07:17 PM
DrewE's Avatar
It sounds pretty normal to me. There is a small but sometimes noticeable decrease in power when the AC compressor kicks in.
I remember riding as a kid in a Chevy Sprint with a teeny three cylinder engine (rated at all of 60 HP according to wikipedia, if I'm looking up the right model) and an air conditioner. If you were sitting stopped at a light or something when it kicked in, the engine would jump from idle to what sounded like half throttle. If you wanted to get up a hill at something approaching the speed limit, it was essential to turn the AC off.
Old Sep 23, 2016 | 10:55 PM
ghostagent's Avatar
any chance changing spark plugs may help? could it be misfiring?
Old Sep 24, 2016 | 12:08 PM
Carbuff2's Avatar
^^^ I doubt it.
If the issue concerns you so much, perhaps you need to have a mechanic or knowledgeable owner take a drive with you. They will advise if its an issue that you need to resolve.
Old Sep 24, 2016 | 10:17 PM
doctor J's Avatar
The live data scanner can be used to watch the MAP reading while driving with ac on at steady 50 mph on flat road. The data can be written down and posted here. I am planing to do same for my car because on some days it is more lazy than on others
kennef
May 29, 2010 11:54 PM
Buck
Jul 8, 2008 06:10 PM
piperpiperpiper
Apr 21, 2008 11:56 AM
RomeoJunior
Jan 29, 2007 05:15 PM
sillypuddy
Nov 23, 2006 03:34 PM
