What is your MAP reading at idle?
Old Oct 14, 2016 | 10:18 AM
doctor J's Avatar
For those who have OBDII scanner with live data could you post your MAP reading on idle (in Park or in neutral for MT) with ECT above 79 degrees C
Thanks!!
Old Oct 22, 2016 | 07:39 AM
doctor J's Avatar
OK never mind, copy-paste experts
Looks like only I have a scanner with a live data
It reads 26 or 27 at idle (in park without load with engine at 79 degrees C)
Old Oct 22, 2016 | 09:25 PM
ezone's Avatar
It reads 26 or 27
What measurement units is this displaying?
I have my scanner set up to display the MAP sensor value as the actual sensor voltage output.
Old Oct 22, 2016 | 10:01 PM
doctor J's Avatar
It reads in kPa (I would be happy to see your reading in volts and convert it)
Thanks!
Old Oct 22, 2016 | 11:29 PM
ezone's Avatar
This was a general rule of thumb (but not carved in stone) on most Hondas with a cable operated throttle and speed-density fuel injection, and seems to pretty much work with electric throttle engines and those using MAF (maybe with some slight response differences):
At sea level, at operating temperature, at idle, in park or neutral, zero additional electrical loads, MAP voltage is typically seen in the .80v to .90v range.
(Readings may change with altitude.)
If it is higher than that, say 1.0v or higher, tight valve clearances might be a prime suspect. Some tight valve issues don't even raise the value that high.
A stuck open or leaking EGR can also lower manifold vacuum/raise MAP voltage
damoaten
Aug 21, 2024 04:17 AM
radioarno
Feb 4, 2017 06:48 PM
De36
Jun 2, 2016 06:31 PM
Wreck Ignition
Aug 20, 2015 07:23 PM
gthumb23
Oct 18, 2006 01:05 AM
