Diagonal Rod Near Tire
Old Jan 2, 2017 | 04:18 PM
MarissaRose's Avatar
First time posting and I've searched for this problem and haven't found a thread.
I'm usually just searching and find solutions over the past three years with my fit.
Anyway, there's been some odd noise near the passenger tire the past two weeks. I wrote it off and decided I'd bring it in at some point. Today I took a turn and it got much louder. Got home and took a look around. Thankfully it's not the tie rod...that would've been bad. But I don't know what this is or how to fix it.
Thanks in advance!
Attached Thumbnails Diagonal Rod Near Tire-80-img_1769_7adca106505d2ad559fddede7b9ee4cdca5c5295.jpg   Diagonal Rod Near Tire-80-img_1770_7ffc14968af0dfe537ffe0a52db7953f0dd592a6.jpg
Old Jan 3, 2017 | 02:15 AM
Rollerboots666's Avatar
It's your sway bar link end. Easy fix but you SHOULD REMOVE it for the time being to drive the car. You can drive with only one side attached until you fix it without any harm or damage to the vehicle.
Old Jan 3, 2017 | 02:20 AM
Thank you! Saved me a lot of worry. Minnesota salty roads are no good for anything under the car.
Old Jan 3, 2017 | 12:59 PM
doctor J's Avatar
Mine was making loud noises until I changed it (driver side) at 40,000 mi.
In order to change it, BOTH front wheels must be off the ground
wwjd
May 14, 2011 11:13 PM
jinjinweiwei
Apr 29, 2011 01:34 AM
TheDirtyBaby
Mar 25, 2011 06:35 PM
bryanback
Apr 30, 2008 08:16 PM
nsx280ps
Feb 5, 2008 07:08 PM
