2007/75k miles transmission failed
Old Feb 5, 2017 | 06:26 PM
RA020726's Avatar
I was at a red light and suddenly my Fit wouldn't go into gear. Got a tow and they told me the transmission is done, one the gears was damaged. Is that pretty rare for car with only 75k miles?
Old Feb 6, 2017 | 01:23 PM
Doug Just Doug's Avatar
Manual or auto? Did a dealer or mechanic you trust tell you that? I'd always suspect a clutch first.
Old Feb 6, 2017 | 07:21 PM
RA020726's Avatar
sorry, it's an automatic
Old Feb 6, 2017 | 08:37 PM
Carbuff2's Avatar
Ever replaced the ATF? At 75K miles its pretty old (ESPECIALLY in the stop & go environment that is NYC).
If your ATF was never replaced you might only have clogged solenoid gasket screens. These are external to the transmission..might be worthwhile to check, not much to lose.
Anyway, I've not yet heard of a Fit AT dropping a gear, EVER.
Old Feb 6, 2017 | 08:42 PM
Dean's Avatar
Yeah, 1st I've read too and there are probably a gazillion automatic GD3's with tons of miles that have never changed their transmission fluids.
Old Feb 6, 2017 | 09:47 PM
doctor J's Avatar
To O.P.
Any motion in reverse?
Do the idle drops when going from P to D?
Grinding noise when going from D to P??
Before tearing transmission down check the passenger side drive shaft!!
Old Feb 6, 2017 | 09:58 PM
RA020726's Avatar
there was a large thunk sound when the light turned green, when I shifted, there was bit of a grinding sound...
once of the gears got damaged so I'm getting a used transmission put in. I don't think I ever changed the ATF, but it wasn't dry...
Old Feb 6, 2017 | 10:07 PM
doctor J's Avatar
The axle is likely popped out from intermediate shaft CHECK THIS FIRST!!
The gear CANNOT break like this!!
the piece to the right of the round aluminum bracket..
Old Feb 7, 2017 | 08:25 AM
Carbuff2's Avatar
Yup, it's also possible that an axle has snapped at the collar on the driveshaft (due to rust).
Old Feb 7, 2017 | 09:36 AM
doctor J's Avatar
thud or clunk -- from broken axle
grinding in park from trying to lock the spinning output shaft
Old Feb 7, 2017 | 11:36 PM
ezone's Avatar
Broken axle should be easily seen if you look.
Rust weakened it and it broke where a rubber donut was wrapped around the middle of the shaft.
Replace original axles. Very common in the rust belt.
The aftermarket axles I installed in mine have no rubber (damper) covering the center of the shaft.
Kevin Evans
Feb 14, 2017 11:03 AM
jessicairene
Jul 18, 2013 12:50 AM
ian2012
Apr 9, 2012 07:08 PM
drzenitram
Apr 13, 2008 02:48 PM
DeadlyAcuraccy
Jan 26, 2008 08:07 PM
