Door Locks Won't Work Anymore.... yes, I checked fuses
Old Jul 8, 2017 | 09:31 PM
tecra's Avatar
Unhappy Door Locks Won't Work Anymore.... yes, I checked fuses
i replaced the rear speakers today on my 07 GD3 sport and after everything was completed perfectly i went to lock the doors and no locking by key fob or by drivers door panel.
first thing i did was check the fuse panel and #28 was blown (door locks) and then i went down to the auto store grabbed a few 20A mini fuses to replace it. boom, blew again as soon as i hit the lock or unlock button. any ideas here? i am hella frustrated
Old Jul 15, 2017 | 08:33 AM
john380's Avatar
My guess is you accidentally pinched/shorted a wire in the door, retrace your steps and you should find the fault.
Old Jul 15, 2017 | 10:12 AM
tecra's Avatar
i am going to do that today, thanks!
Old Jul 21, 2017 | 03:24 PM
tecra's Avatar
welp i did everything again. remove door panels, checked speaker wiring, check the stock electrical wiring throughout the doors and still cant get the darn door locks working FFFFFFFFFFFFCCCCCCCCCCCCCCCCCKKKKKKKKKKKKKK
Old Jul 21, 2017 | 05:21 PM
bargainguy's Avatar
If I had to guess where the short might be - and there's gotta be a short somewhere, as the locks were working fine before you replaced the speakers - I'd guess the plug-in white plastic electrical connector in the arm rest.
Pry up the arm rest cover, unclip the arm rest connector, and inspect to make sure everything is as it should be - no bent pins in the connector, frayed or exposed wires going into the connector, etc. If you don't find anything on one side, inspect the other.
I can't think of anywhere else you might have disrupted the flow the electricity to the door locks just by replacing speakers.
Old Jul 21, 2017 | 05:49 PM
tecra's Avatar
Hey thanks for the point in the right direction! I guess I'll be pulling off the door panels again this weekend for the 5th time 😂
Old Jul 22, 2017 | 05:14 PM
tecra's Avatar
and i found it! drilled into the electrical lines on one of rear speakers. just unwound her out a bit and now the car locks again. thanks for the pointers gentlemen!
Old Jul 22, 2017 | 08:20 PM
bargainguy's Avatar
Hey, good for you! Enjoy those new speakers!
wutangben
Jan 19, 2020 05:18 PM
~Lesly~
Jul 9, 2019 11:36 AM
Hondarian
Apr 24, 2016 05:29 AM
radiolandog
Sep 8, 2014 06:57 PM
VBee
Mar 15, 2014 05:11 PM
