Constant squealing while driving/idling
Old Jul 19, 2017 | 02:31 PM
Fit2008man's Avatar
Hey guys, my 2008 Fit is making a squealing noise when it's idling and when I'm driving (it's constant). Does anyone know what this noise could be? Car has regular maintenance and the oil level is good. Also, the AC recently stopped working... could be related?
Here is a video of the noise.
Thanks in advance.
Old Jul 19, 2017 | 03:39 PM
doctor J's Avatar
can be idler or a/c clutch bearing. Remove belt and spin each component to check
Old Jul 19, 2017 | 06:28 PM
snit fit's Avatar
Sounds like a bearing getting ready to explode. Definitely get it fixed asap. Could be the A/C clutch, but could also be the water pump or any number of other belt driven pulleys and components. If it fails it will take out the belt and leave you stranded.
Old Jul 19, 2017 | 09:37 PM
doctor J's Avatar
While it may not be exact cause for this case, but when I saw high mileage 08 Fit on local wrecking yard, the original water pump pulley moved very smooth and had no play, while idler pulley bearing was very rough as well as a/c clutch bearing.
Old Jul 20, 2017 | 07:52 AM
Carbuff2's Avatar
Our '07 had a bad A/C clutch that was making a similar noise.
Old Jul 20, 2017 | 10:29 PM
Fit2008man's Avatar
Thanks everyone!
07FitSprt
Feb 24, 2019 09:06 PM
redludesh
Apr 22, 2018 10:18 PM
omega505
Nov 29, 2017 11:56 AM
viperpit07
Nov 8, 2015 09:52 PM
trinisir
May 11, 2015 08:47 AM
