5speed Stuck in Neutral
Old Sep 10, 2017 | 01:52 PM
short1's Avatar
Need some help, my Fit won't go into gears. 08' sport, 5speed, 109k miles, 30k on new clutch. It's seemed to be stuck in neutral. It was very hard to move side to side at first, now It will go into 1st 3rd and 5th. There is no moving the shifter down. Whether the car is on or off, or clutch is depressed or not makes no difference. Fluids look fine, clutch pressure feels normal. Was fine last night, hopped in today and no go. The only things i can find searching talk about if it shifts when car is off it's the clutch, cannot find anything for my problem
Old Sep 10, 2017 | 02:38 PM
Rollerboots666's Avatar
Its most likely your cable. Inspect the cable and see if there is a tear or opening in the housing. I had this happen to me and there was a tear in the housing making the cables push through on 2,4,R.
Old Sep 10, 2017 | 03:56 PM
short1's Avatar
Thanks for your help! Wasn't what i expected to find...seems a critter decided that this was a good place to stash a walnut!
Old Sep 11, 2017 | 03:40 AM
Carbuff2's Avatar
Nice detective work!
That was a 'nutty' problem. (Couldn't resist!)
Old Sep 11, 2017 | 01:39 PM
MobiuS's Avatar
I'm so happy that you posted the solution as a photo
Old Sep 11, 2017 | 02:17 PM
radioarno's Avatar
ha! That's nuts! Great catch!
Old Sep 14, 2017 | 09:47 AM
AnalogDog's Avatar
Looks more like a lime...
Old Sep 14, 2017 | 10:59 AM
radioarno's Avatar
https://en.wikipedia.org/wiki/Walnut...ssfrucht_2.jpg
yep, walnut in its husk looks like a lime.
Old Sep 17, 2017 | 01:59 PM
The Fitness's Avatar
You put the Lime in the Fitconut!
Aaronbodywork@gmail.com
Nov 21, 2019 07:31 AM
cgpEJ6
Aug 31, 2017 11:50 AM
TOORAPH
Sep 12, 2015 01:36 AM
Rollerboots666
Oct 15, 2012 07:54 PM
SammiJo
Jul 25, 2012 06:59 PM
