"Mode Control Dial" broke
Old Dec 1, 2017 | 12:09 PM
bikerdrumr's Avatar
Hi,
Anyone ever repair the module that the "Mode Control Dial" for the climate control? It's the knob that controls which vents the air or heat comes out of. Here are some specifics: It still activates the A/C when put in defrost BUT the cold air only comes out of the front vents, not the windshield vents. I can still change the temperature from hot to cold but the air ONLY comes out of the front vents. I'm just assuming that there are flaps in the HVAC that direct air from one set of vents to another. So, those flaps aren't moving.
Any ideas?
Dave
Old Dec 2, 2017 | 09:36 AM
doctor J's Avatar
Make sure there no foreign objects is in the ducts first and nothing is restricting movement of the mode lever under dash.
Pull out glove box (like for cabin filter change) and inspect
Old Dec 2, 2017 | 11:09 AM
ezone's Avatar
There is a push/pull cable between the control dial and the heater box in the dash. (one of three cables total)
You'll have to investigate if that cable still moves or not, and see where in that the movement was lost or broken.
Old Dec 2, 2017 | 04:57 PM
bikerdrumr's Avatar
Awesome! I was going to replace the cabin filter tomorrow anyway. Upon first inspection, I didn't see any moving parts when I moved the dial. But I'll have more time to check it out.
Thanks, I really appreciate the response!
Old Oct 13, 2018 | 11:37 AM
Denise Toman's Avatar
I have the exact same problem
The cable that connects from my vent control knob to white disk isn’t moving when I turn the dial. Is this an easy fix? What do I call it when requesting this cable at the parts store? Thanks for you help!
Old Sep 13, 2019 | 12:19 PM
juliefirl73's Avatar
mode control knob repair
Still don't know where to find the part though
htimsda
Nov 14, 2024 09:56 PM
Lakeshore Fit
May 27, 2015 12:02 AM
75r90rider
Sep 26, 2014 06:22 PM
GTRPLYR
Jan 18, 2012 04:00 PM
Sherpa
Sep 2, 2010 03:48 PM
