Fans going nuts after coolant flush!
Old Feb 27, 2018 | 02:45 PM
cakacon's Avatar
Hey guys,
I just wanted to see if any of you had issues with your fans constantly turning on and off after a radiator flush. I burped the radiator already (twice actually). Do you think the thermostat isn't opening at all? The car isn't overheating (at least the lights not on), but the fans are literally turning on and off every second. It did not do this previous to the drain/fill/burp. Thanks in advance for any insight and God Bless!
Ross
Old Feb 27, 2018 | 11:40 PM
cakacon's Avatar
Additional
Also, this is not happening in defrost mode, AC, etc. I know the fans kick on then. Thanks!
Old Feb 28, 2018 | 08:04 AM
Carbuff2's Avatar
You surely have an air bubble (that the fan sensor is 'reading').
Run the engine for 10 minutes. Hold the RPM at 2000 RPM a couple times to get the flow rate higher.
Turn the car off and let it heak-soak a few minutes. Then top-up the cooling system.
Monitor the coolant level for the next 4 - 5 drive cycles.
Old Feb 28, 2018 | 03:40 PM
doctor J's Avatar
Check connector on the radiator fan sensor (bottom radiator tank) for coolant contamination or mechanical damage
Old Feb 28, 2018 | 09:17 PM
cakacon's Avatar
Ive tried this a few times already, I'm not sure it's doing anything else, but I am gonna try it again, thanks!
Old Feb 28, 2018 | 09:20 PM
cakacon's Avatar
This is actually what I was kind of thinking to check next. Where exactly is this sensor? So you mean the overflow tank? Thanks in advance!
Old Mar 2, 2018 | 12:02 PM
doctor J's Avatar
Lower radiator tank, next to the lower radiator hose across the oil filter (may need to remove splash shield to spot it right away)
fuldog
Dec 22, 2015 06:12 PM
wzard999
Nov 17, 2013 08:58 PM
Bugzs15
Nov 5, 2013 06:57 PM
Oofie
Jun 18, 2011 05:50 PM
fit4jdm
Oct 21, 2008 01:39 AM
