Dead Pedal for GD - Questions and Interest?
Old Mar 22, 2018 | 05:42 PM
GQ_Style's Avatar
Lightbulb Dead Pedal for GD - Questions and Interest?
I'm not sure which is the bigger sin, to revive an ancient thread or to start a duplicate thread years later. (Yes I searched). The original thread is here:
https://www.fitfreak.net/forums/fit-interior-modifications/9264-dead-pedal-photos-diy-answers-questions.html
Sorry for invoking an ancient thread. I reached out to Zeta recently to offer to purchase a large quantity of the GD dead pedals at once if they will custom run a large order for me. They replied that it is impossible because they had destroyed all the associated tooling for it. Sad. I guess I am forced to try to reproduce one. If you gentlemen ever take yours out and can take measurements for me, I will see about having a quantity sheet cut and bent as a one-off run. I like the idea of bolting it to the hood release bolts but wanted to hear what your thoughts were for improvement over the original. I'll likely try to design something and do a small batch run over the upcoming summer in case anyone is interested. I have access to a laser cutter and a metal bender.
I wanted to see if there was any interest and also suggestions for improvement. I am only going to do a LHD version since I don't have access to a RHD GD for fitment. Some folks mentioned that the original was uncomfortable, what would you do different if i could redo the GD aftermarket dead pedal. Pictures of the underside of the dead pedal would be helpful. My goal is to have this design flat cut from sheet metal and bent, barring that, it will be a lot of brazing.
Old Mar 28, 2018 | 05:59 PM
Lance's Avatar
Doit!
Finally someone to undertake this dead pedal task is here! Be if no one else wants one and you do end up making 1 please make me one.
I also contacted zeta and they told me no can do months ago and nobody sells their personal ones for me to buy either.
Im getting a set of dot legal ss brake /clutch line made in the near future and will get 2 sets fabbed. Trades? Lol all in the sky for now.
Old Mar 28, 2018 | 07:38 PM
GAFIT's Avatar
We have one. The only thing I would change is a slight pitch adjustment. The Zeta pedal is slightly pitched toward the door instead of being flat.
Nit picky as it's still a monumental improvement for driver comfort vs no pedal at all.
If you stick with this plan and no one else comes forward, I can remove ours and get measurements.
Old Mar 28, 2018 | 08:47 PM
paynomind's Avatar
In for one
I love this idea! I'm in for one, if the price is reasonable!
(And I am the one who sinned by replying to that old thread. Mea Culpa!)
Old Apr 4, 2018 | 08:48 AM
geopat's Avatar
Pictures would be great. Would like to make one for myself since I have missed out on the last couple that have come up for sale used
Old Apr 9, 2018 | 03:04 PM
GQ_Style's Avatar
The one from Zeta looks like this:
Pretty straightforward, 5 major visible pieces to weld together (2 x bolt supports, 1 x L brace, 1 x pedal face, and 1 x pedal underside support). 3 pieces to bend (2 bolt supports and 1 L brace). Summer project most likely. I'll make extra few prototypes. Based on the response, I don't see great demand for this product. Not doing this commercially, so if you want an guarantees on beauty or whatever, keep looking for a used Zeta. This will likely stay a prototype product, enough to share some costs to offset just making a single unit. I just need a unit for myself.
I'll do it in cardboard first to get a template. See if I can rent time on a sheet metal cutter. My TIG welds are ugly guys, be warned. I guess I can also sell an unwelded kit for you DIYers with nice MIG welding rigs. Lol.
Old Apr 9, 2018 | 05:19 PM
GAFIT's Avatar
I think there's more to the design than you realize. Not that it couldn't be simplified, but there's more going on than you see in that picture.
Finally back from a long trip so I could pull ours out and get a few pics. More available upon request...
Old Apr 9, 2018 | 06:07 PM
GQ_Style's Avatar
Can you put a tape measure to each of the bendy pieces? So I can get rough measurements for the items in red? Photos are fine. Thanks for the pictures of the rear. Still pretty straightforward, but you were right about it being a bit complex still. Can you also give me a thickness measurement. Look like 1/8" thick sheet steel, hard to bend.
Old Apr 9, 2018 | 06:23 PM
GAFIT's Avatar
Since you are clearly better at photoshop than I am , could you add letters to the lines? That way I can give you A measurement, B measurement, etc.
I don't know why, but they used four different thicknesses of metal. The large bracket is actually 3/16" (7 gauge), the short C in the back is 9/64" (10 gauge), the parts that bolt to the hood latch seem to be 1/8" (11 gauge), and the pedal itself is 5/64" (14 gauge).
Wife put her calipers to use for those. We subtracted some for the powdercoating to get those numbers.
Old Apr 9, 2018 | 07:55 PM
GQ_Style's Avatar
Originally Posted by GAFIT
Since you are clearly better at photoshop than I am , could you add letters to the lines? That way I can give you A measurement, B measurement, etc..
Here you go. Thanks for taking time to do this. Also let me know where the improvements can be made.
E1 is distance from center of one hole to the center of the other hole. Also tell me in F1 how large the hole is while you are in there. 8)
Also can you take a photo of the side of this bracket. I'd like to better understand the angle.
Old Apr 9, 2018 | 08:49 PM
GAFIT's Avatar
A1 - 1.25"
A - 2 1/4" (flat part is just under 2")
B1 - 2 1/2"
B2 - 1 1/2"
B3 - 1 3/4"
B - 7"
C - 2 1/8"
D - 2 1/8"
E - 3/4"
E1 - 2"
F - 3/4"
F1 - 3/4"
G - 3"
H - 1 3/4"
i - 1 1/2"
J - 3 1/2"
That bracket is a compound angle as you apparently suspect. Not sure how to even describe it. Will work on a pic.
Old Apr 10, 2018 | 01:36 PM
GQ_Style's Avatar
F and F1 should not be the same. F1 should be the diameter of the hole. F should be the plate that has the hole and should be larger than F1. Don't forget about K. Just checking. Thanks for the measurements!
Old Apr 10, 2018 | 11:17 PM
geopat's Avatar
Thank you GAFIT for the pics and measurements. That bracket is a lot beefier then I had thought.
Old Apr 12, 2018 | 09:24 PM
GAFIT's Avatar
Sorry, F1 is about 5/16".
This gives an idea of the compound angle...
Old Apr 12, 2018 | 09:26 PM
GAFIT's Avatar
Welcome! It is a well made piece. I wouldn't be posting dimensions and details if it were still available from Zeta. At this point, it's just a community service to provide details.
We have the zeta hood deflector also and, 10 years later, it's still a good piece as well.
Old Apr 16, 2018 | 11:56 PM
paynomind's Avatar
Still in
Hey GQ, I'm still in for one. Happy to share some costs!
Old Apr 18, 2018 | 07:41 PM
User1's Avatar
I'm in for one if it's reasonable in price. I'm hoping the pedal doesn't take that much needed space. My seat is to the back all the way as it is now, and that's without a dead pedal.
BTW, I'd go with a thinner metal if I was building this. Something some might consider "flimsy".
Old Apr 19, 2018 | 10:24 PM
Lance's Avatar
Still down
Im all the way in for this. Fingers crossed. Please make me one im paypal ready when they are done.
Old Apr 24, 2018 | 03:39 PM
skiboarder119's Avatar
Me too, I need one as well.
As a engineer who works on sheet metal parts, I'm thinking we could reduce it from 5 parts welded together to 2 parts (maybe 3 worst case). This would keep costs down. We should be able to get these made for about $50 even after a nice high quality powder coat.
Old Apr 24, 2018 | 05:20 PM
GQ_Style's Avatar
The thickness is a bit beyond what i expected for "sheet metal". Definitely thicker than what my local sheet metal folding jigs normally do. This is more like a thick sheet of metal in some places. I think we can still make it work. Again folks this is a summer project.
