What is the horrific sound my 2007 is making?
Old Apr 21, 2018 | 09:43 PM
redludesh's Avatar
At about 20 seconds I rev it. It sounds like I have a supercharger when I give it gas. Only thing I know that is wrong with it is AC doesn't work at all.
thank you.
Old Apr 21, 2018 | 09:59 PM
geopat's Avatar
It is probably the bearing in that idler pulley at the top there. I would pull the belt and spin the pulleys to see if they make noise or feel rough.
Old Apr 22, 2018 | 08:27 AM
Carbuff2's Avatar
Might be the A/C clutch bearing, that would be the second guess.
It's REALLY hard to tell from the vid, but inop A/C is a big clue.
Old Apr 22, 2018 | 10:34 AM
redludesh's Avatar
Here's underneath I'll pull the belt today and see if I can figure anything out.
Old Apr 22, 2018 | 10:42 AM
doctor J's Avatar
Idler or a/c pulley bearing
Old Apr 22, 2018 | 12:11 PM
redludesh's Avatar
So replacing the ac compressor should solve both of my problems?
Old Apr 22, 2018 | 06:58 PM
Carbuff2's Avatar
You could replace the compressor or just the clutch. (When our clutch failed, we found that it cost the same for an entire reman compressor as the clutch alone, which was only available through a Honda dealer.)
Old Apr 22, 2018 | 10:18 PM
GQ_Style's Avatar
Idle pulley. it's a cheap part that you can replace yourself.
RyanM
Nov 21, 2024 09:40 PM
iandunham
Dec 1, 2019 05:09 PM
Fit2008man
Jul 20, 2017 10:29 PM
angryhippie
May 27, 2015 10:13 AM
stevenr
Jun 27, 2014 10:13 PM
