Air conditioning issues
Old Jun 13, 2018 | 07:20 PM
cakacon's Avatar
Hey guys and gals,
​​​​​I am having problems with my Ac. I had my compressor replaced a few years ago. The other day randomly my ac clutch won't turn on. I was hoping I would be lucky enough for it to just be a common relay switch replacement. Unfortunately it was not. So I have 2 questions: 1st where is the ac pressure switch located on the fit (can't seem to find it in my Hanes manual), and 2nd where is my ac grounded, as maybe the ground broke loose. I understand that it could be the Condenser is leaking refrigerant. How hard are the Condensers to replace? I definitely won't spend the money on a new Condenser, but I'm hoping it may just be a bad ground. Thanks in advance for any input and help!
God bless,
Ross
Old Jun 14, 2018 | 10:35 AM
doctor J's Avatar
Get a gage from Pep Boys (Pencil Gage) https://www.pepboys.com/product/deta...745?quantity=1
and measure pressure at low side with engine is not running (it should read above the scale, approx 80 PSI)
If it reads low there is a leak.
Old Jun 14, 2018 | 12:24 PM
cakacon's Avatar
Thanks That's my next step!
Old Jun 16, 2018 | 03:03 PM
benmaggoswd1's Avatar
Did you need to recharge the system before positive diagnosis on the compressor?
Sorry. Hijacking your thread for my own issue with AC.
Old Jun 17, 2018 | 07:46 AM
jbbuilt's Avatar
Push on clutch plate with a stick when it is on and see if it will engage.
Old Jun 18, 2018 | 10:27 AM
Alco RS-1's Avatar
A long shot guess, but did you have a lot of weight in the car? I ask because last month the A/C in our GE (Gen2) Fit quit while driving home from college with a very heavy load of stuff.
After unloading the car the next day, I was stumped because the A/C worked fine and it's since been perfect everyday.
Friends on FitFreak suggested the heavy engine load was the culprit and they appear to have been correct. I read elsewhere a passionate argument that the Fit is not equipped with a system that cuts off the A/C under heavy engine load, but I can think of no other reason for the reaction of our Fit.
Old Jun 18, 2018 | 10:41 PM
fujisawa's Avatar
Alco -- the GE, at least, ARE equipped with a system that cuts AC if you floor the pedal. Rationale is that wee engine of ours needs every last hp (and AC drag is not small on an engine with 115hp!). I don't know how the system is managed. I find it's not good enough and the car feels generally sluggish with the AC on. I'm not surprised that driving with a really heavy load, the car might keep the AC clutch off more of the time. Cool anecdote.
Old Jun 19, 2018 | 11:25 AM
Alco RS-1's Avatar
Thank you for your post confirming the feature fujisawa. At the time I was expecting that a high dollar repair was in my future and it was nice to find that all was well.
Old Jun 27, 2018 | 10:57 AM
vap3's Avatar
my ac was dead for awhile and the dealer wanted a new relay and something for almost 800 bucks in parts im like wtf!
found a junkyard compressor for 150 haha and then honda will charge me 2 hours of labor, over 50% savings baby! 90 day warrenty part, worth the risk for a car that's worth just over 2k
Alexander Gish
Jul 13, 2018 05:33 PM
phybere
May 29, 2018 11:46 PM
gahris
May 14, 2017 04:51 PM
MorganKl
Jul 1, 2013 01:49 AM
fmstrohl
Jul 5, 2006 04:51 AM
