Junk yard practice: windshield wiper linkage and dog poo in the car:)
Old Jun 25, 2018 | 10:18 AM
doctor J's Avatar
Once another Fit hit the junkyard, I went to check it out.
My subjects of interest are:
- front brake rotors (I noticed some scratches on them when changed pads)
- windshield wiper linkage assembly removal (replacement anticipated due to the white plastic parts corrosion)
- a/c clutch
- radio (LCD screen)
- rear brake shoes R&R
The rotors on the car were original; the Valucraft pads ate them really bad, yet made nice and flat finish; these pads can be installed to condition the rotor instead of machining it (for no more than 300 miles) between the OEM pad changes
The windshield wiper linkage removal is shown below (photos by my vintage flip phone
Wiper arms removed (14 mm nut), right cowl cover removed
Left cover removed; time to unbolt three 10mm screws and disconnect electrical plug from the motor
Close up
These two Phillips screws that are attaching motor to the beam are installed with thread locking compound and will require additional steps to remove! I used an impact without much of the success!
One more view of the screws; the nut on the motor came out very easy
The ac clutch 14 mm nut can be removed after immobilizing the plate with flat bar or screwdriver
Insert screwdriver between two round bosses as shown; use box end offset wrench to keep it in place when undoing the nut
The removal of the radio was called off after I found a dog's poo on the floor; the question is: did the poop took place before or after an accident?
Despite disgusting interior, the owner took a good care of the headlight by applying clear coat to it
Note: the horizontal plastic tabs immediately below the headlight are very fragile and can break easy during bumper removal!
The rear brake shoes removal was more difficult than anticipated (at least when following service manual procedure); perhaps need to make a special tool for a spring at the bottom (my huge brake spring tool does not fit into the return spring)
Thanks for reading! I am waiting for next Fit!
diesehrl
May 25, 2019 09:20 AM
strmslvrfit
Jan 7, 2015 11:17 PM
degnaw
Aug 31, 2014 04:08 AM
shawnshank
Oct 19, 2013 04:45 AM
LizardKing
Feb 20, 2008 03:36 PM
