08 Manual Transmission Fluid change
Old Aug 19, 2018 | 09:49 PM
gqcpa's Avatar
Hi,
Can someone show me where is the fill hole for a 2008 Honda Fit manual transmission fluid?
Thx!
Old Aug 20, 2018 | 08:03 AM
Carbuff2's Avatar
Its #9, the other bolt with a 3/8" square hole (besides the drain bolt #10)..
Full image and parts callout:
https://www.hondapartscheap.com/auto...sion-case-scat
Old Aug 20, 2018 | 10:06 AM
gqcpa's Avatar
Thank you CarBuff2. Yes manual does rule!
GQCPA
Old Aug 20, 2018 | 10:31 AM
Mister Coffee's Avatar
Buff, with all due respect for your greater wisdom and knowledge, are you sure it isn't #14 on that diagram?
Old Aug 20, 2018 | 10:49 AM
GAFIT's Avatar
I'll add just in case the OP isn't a regular at transmission fluid changes...
Remove the fill plug before removing the drain just to make sure it comes out OK. Don't want to drain and then not be able to fill.
Old Aug 20, 2018 | 01:16 PM
Carbuff2's Avatar
Can't remember, its been a while. And the Fit isn't nearby. (Thanks for being tactful...)
Look for the aluminum crush washer under the fill bolt (both fill & drain bolts have a crush washer). If its a regular steel washer, that ain't the bolt to touch. The descriptions in the full link are not helpful...
(I never had difficulty finding either.)
sultanofslide
Jan 14, 2021 11:33 PM
Sonnington
Sep 17, 2018 09:04 PM
dvoisawesome
Dec 12, 2017 02:43 PM
mole177
Feb 25, 2011 02:51 PM
smirff07
Oct 11, 2007 01:07 AM
