1st gen honda insight wheels
Old Oct 15, 2018 | 03:13 PM
silence911's Avatar
Hello everyone, I'm planning to get some 1st gen Honda Insight wheels for my GD. I was wondering if they will fit our cars or not? I am trying to make the car as aerodynamic as possible and sipping less gas.
Here are the info on the wheels
https://www.wheel-size.com/size/honda/insight/2005/
Thank you in advance
Old Oct 15, 2018 | 03:17 PM
evilchargerfan's Avatar
other than tire size, it all looks identical to me (should work fine)
Old Oct 15, 2018 | 08:57 PM
silence911's Avatar
So they went scrape on the brake calipers or the suspension correct?
Old Oct 16, 2018 | 12:21 PM
is there any indication, that suggests that it would do so?
Old Oct 16, 2018 | 06:42 PM
fujisawa's Avatar
Everything looks the same. Should be interesting. The narrower tire will help fe.
Check your clearance on the calipers .. But I bet you are fine
Old Nov 9, 2018 | 08:24 PM
der Mond's Avatar
It appears that the offset is 45 - OEM wheels are 55. The tire will be closer to the lip of the fender. May rub if the suspension bottoms out.
Greg 123
Jul 3, 2016 08:28 AM
Blair Jackson
Mar 16, 2015 03:10 AM
jlandman
Dec 7, 2011 11:54 AM
mattgregory33
Sep 1, 2011 06:50 PM
jaydubz79
Feb 7, 2009 11:32 PM
