GD3 ecu in GE8 for Hondata
Old Jan 2, 2020 | 12:38 PM
Jasonvicktory86's Avatar
Has anyone tried putting a GD3 ecu and harness into a GE8 so you can use Hondata?
i read somewhere on the forums (can’t find the post anywhere) that you can swap the timing gear on the crankshaft and ckp sensor (and I’m assuming the engine harness) and the GD3 ecu will work.
im Turbo now with a Ktuner but I’m dying for more than 10 psi.
As a side note I blew a rod out the pan so I’m building my new motor (JE pistons, Brian Crower rods, arp head studs, and the normal stuff) so I figured it’s a good time to ask)
thanks!
- Jason
Mohamad Fendi Amir Hamzah
Sep 6, 2017 11:12 PM
ivitec
Jun 7, 2013 11:19 PM
bryz_
Feb 20, 2012 06:30 AM
kevsta
Sep 19, 2011 04:33 AM
NotraFit
Dec 22, 2009 03:56 AM
