Skunk 2 Short Shifter??
Old Jun 3, 2010 | 11:10 AM
GrocerySnake's Avatar
Skunk2 Short Shifter Adapter Kit for Honda Fit - JHPUSA
Does this work for our cars??
It says "universal" but nothing more specific. It would be sweet to not have to spend 150+ on a Mugen ss.
Old Jun 3, 2010 | 11:17 AM
truth's Avatar
This is a different approach than the mugen piece.
It might make the stick shorter, but I don't know if it will shorten the throw as much as the mugen piece which is a complete shifter replacement.
Skunk is known for making reliable performance parts though, so it's probably a nice piece all the same. If you get it, let us know what you think!
I got the Mugen item, and must say it was worth the $. The difference in price has a lot to do with what the kits actually come with. $50 for an adapter of sorts vs 150+ for the whole swapped item.
Old Jun 3, 2010 | 11:32 AM
Yea thats what I was thinking. Ill search around, probably call skunk, and if it is for out car, I'll probably try it out.
Old Jun 3, 2010 | 01:05 PM
Ok I called Skunk 2, and they confirmed that its only for the GD.
Does anyone know if the m/t shifter assembly is the same for GD and the GE??
Could this possibly work on the 09+? Ive tried to look it up, part# etc, no luck. Anyone know?
Old Jun 3, 2010 | 01:25 PM
hayden's Avatar
Some are the same as the GD on the GE, but there are two other styles as well, making a total of three shift levers. H-fit makes a compatible one, and I think it's a better deal than the Skunk2. It comes with aluminum inserts and the adapter won't mar the ball on the end like the Skunk. $75 shipped.
Old Jun 3, 2010 | 01:30 PM
Yea I will probably end up going with that if i do get a ss.
But yea after like an hour of interweb searchin, no luck figuring out if the skunk works. Thanks for the input hayden !
Old Jun 3, 2010 | 04:12 PM
JDMchris.com's Avatar
I run THIS
The skunk2 fit's... the shifter assembly's are the same
Old Jun 3, 2010 | 04:18 PM
super_fit's Avatar
my skunk2 shifter adapter is coming in tomorrow ill let you guys know how it went or if i even feel a difference
Old Jun 3, 2010 | 05:36 PM
hayden's Avatar
Not true. H-fit sent me one that didn't fit, and then after investigating some customer cars in their area, they found that there are actually 3 GE designs, where the tapered part at the bottom is the exact same as the GD on one, is longer on another, and some iterations have a flat part machined into the bottom of the ball joint section.
edit: I should add that the Skunk2 might still fit all three since it only connects to the ball section.
Old Oct 29, 2010 | 04:16 AM
SExDEVIN's Avatar
Does the S2 fit ?
knicolas
Feb 3, 2014 09:23 PM
P-Fit
Oct 13, 2013 09:48 PM
Fish
Aug 27, 2009 11:09 PM
samson simpson
Nov 15, 2008 02:08 PM
