GE8 Weapon R Header Question
Old Feb 26, 2012 | 09:56 PM
bdogpot's Avatar
Does any one know what the longer section has for a diameter piping. I want to add a high flow cat on to the pipe and need to know its diametr so I can buy the correct magnaflow cat. Any help would be great. Im not gonna order the stuff until the middle of next month so there is some time to find out.
Old Mar 14, 2012 | 03:10 PM
mole177's Avatar
are you planning to cut a portion of the pipe so you can attach a cat?
Old Mar 17, 2012 | 05:42 PM
bdogpot's Avatar
Yea I going to cut a section out so I can put a high flow cat. I looked all over and could not find a bolt on high flow cat, so I will just do it my self.
Old Jun 10, 2012 | 11:37 PM
wontfit's Avatar
How the fark are you installing a header when it's integrated on the head?
Old Jun 10, 2012 | 11:55 PM
555sexydrive's Avatar
WeaponR released a downpipe that eliminates the primary and secondary catalytic converters. Not sure if they actually market it as a header, but being as you mentioned the GE has the primary pipes cast in, it's the closest thing one can get to an exhaust manifold for it.
Old Jun 11, 2012 | 12:30 AM
wontfit's Avatar
Ah. I honestly have not crawled under the fit further than oil changes, does each cylinder have a chamber? Or is it Hondas crazy two cylinders share a tube and that deads into a poipe?
Old Jun 11, 2012 | 03:29 AM
Well you see just 1 opening split into 2, inside that there are like 8 openings, 1 for each valve it seems. Scroll down this large JPEG. Thanks to WongKN for this.
Old Jul 17, 2012 | 06:32 AM
Azizul Zulzaha's Avatar
i have the closed-coupled Cat Con & the under-floor Cat Con removed, and install cheap-ish test-pipe that is a one-piece thing that replaced both the CAT CON. good performance, but not very reliable since its a cheap-ish grade.
not it has this hissing sound after a year, maybe leaking air/pressure...dunno
Old Aug 21, 2012 | 03:50 PM
y950129's Avatar
I have one for myself and wut a difference it makes... it certainly does not look like a normal header but sure makes the car faster and louder
GE8FTW
Sep 23, 2021 05:16 PM
SlowFit13
Dec 11, 2014 07:04 AM
lobomac
May 31, 2011 06:56 PM
xlipx
May 27, 2011 06:15 PM
Bthasht
Apr 6, 2011 03:16 AM
