51R Battery Upgrade on my '09 Fit
Old Jan 21, 2016 | 12:44 PM
Frenzal's Avatar
Originally Posted by slow
Only other thought, is it possible that you have a parasitic load from an aftermarket accessory? I was nervous about my remote start and aftermarket rear view camera, but seem to be OK.
Only aftermarket accessory is a remote starter, installed by the dealer when the car was brand new.
In the summer, I can leave the car parked for many days without issue.
I also own a Honda Accord, which can stay for 2 whole weeks in the cold, and still start easy when needed...
What was Honda thinking by using the 151R battery in cold climate??
Old Jan 21, 2016 | 02:13 PM
Oneoldphlaytis's Avatar
re: leftovers
So you should have one extra of each 5505 and 5515, but black instead of red. Would you like to sell them?
Old Jan 22, 2016 | 04:32 AM
Black3sr's Avatar
Hey Canucks. I just had my stock battery replaced at the dealer. I missed the two year full replacement wty but did get 60% off. So if your battery is not that old I would keep nagging Honda to replace it and make sure to get discount or full replacement.
I had the battery replaced two years ago but in that two years I managed to kill it a few times with wiring projects. I suspect this led to its' early demise.
Old Jan 25, 2016 | 05:45 AM
Frenzal's Avatar
Car did not start again this morning... Was last driven on Saturday PM!
Stupid battery!
Old Feb 14, 2016 | 12:06 PM
Frenzal's Avatar
Went to Mexico last week. The Fit sat in the airport garage at ~70 degrees for 7 days, and would not start when I came back. Luckily, my father in law also came with his car so he could boost me. That does it for me: tomorrow morning, I'm going to Honda and won't leave until they change the battery. At least I should get through the rest of winter with a new 151R battery. Then this summer or fall, I'll do the switch to the 51R battery for next winter.
Old Feb 14, 2016 | 12:09 PM
xxryu139xx's Avatar
i keep my oem 151r battery in the garage. i keep it charged with the tender and use it as a battery booster/jumper.
Old Feb 15, 2016 | 08:03 AM
Frenzal's Avatar
Well...couldn't even start the car this morning. Battery has been connected to a charger during the last three days...
This is proof that my battery is defective and needs to be replaced. Will have the car towed to the dealer today.
Everything should be free (under warranty)
Old Feb 15, 2016 | 09:13 AM
xxryu139xx's Avatar
not really Frenzal. I thought the same when I started having problems with my 151r and then the 51r battery. Turns out my Big 3 Battery Ground has started to come loose from the chassis and some wires became frayed and exposed. Jumping the battery was erratic. It would only start if i put the jumper ground somewhere on the chassis. I cleaned up the wire and tightened it. No problems anymore.
Old Feb 15, 2016 | 03:31 PM
Frenzal's Avatar
Finally, dealer replaced the battery. Battery was defective and had some bad cells in it, so I was maybe on 9/10 or 4/5 (or maybe less) of the battery.
Car is cranking fine now. In fact, it has been a long time since I heard it crank that way.
Might postpone the 51R swap when this new battery is dead. But at least I'll be ready with all the necessary parts!
Ryu: Really a good idea to check grounds in fact...but since my car is only 1.5 years old, everything should be OK on that side (at least for now).
Old Mar 1, 2016 | 03:44 PM
kitenok's Avatar
The Slight Angle installation seems to work fine. I removed the small battery with a tray changed the air filter put the 51R battery slightly sideways added battery terminal shim to the positive terminal. Tie the battery down. Started just fine -10F. Honda Fit Sport 2009.
Attached Thumbnails 51R Battery Upgrade on my '09 Fit-80-img_2232_015873adb3c89b54da7e6d812bf3e4cb3edd7747.png
Old Mar 22, 2016 | 01:43 PM
tony_2018's Avatar
Whats the reason behind using a different battery that was meant or the Fit?
Old Mar 22, 2016 | 07:17 PM
  #32
Myxalplyx's Avatar
Grab some coffee, popcorn or whatever and read up -->
https://www.fitfreak.net/forums/2nd-...honda-fit.html
The very first post should do it for you but there's plenty to read.
Old Mar 22, 2016 | 07:35 PM
  #33
tony_2018's Avatar
Thanks, so far CLIF NOTES
more cranking amps
battery last's longer
edit: better battery choice for colder climates.
Old May 26, 2016 | 07:14 AM
  #34
Frenzal's Avatar
To be prepared when I'll do the swap to the 51R battery, I just bought a 00 Civic battery tray (00 Civics used the 51R battery).
Part number is 31521-SR3-000 and costs about 12$ (here in Canada, so you US folks should pay around half of that!)
When I do the install, I'll remove the Fit battery tray and cover, then lay a thin rubber on the car battery base (which is metal), then the Civic battery tray, then the battery. Should be a really clean install!
Old Jul 10, 2016 | 12:06 PM
  #35
nickroz's Avatar
Just upgraded my battery. Thanks for the write up.
Old Jun 30, 2017 | 03:53 PM
  #36
FitnForest's Avatar
Can you please reshare the pictures?
Hi! Thanks for sharing this great info! I finally bought the parts that you suggested and came back on here to make my final plans for the battery swap, and for some reason, your detailed pictures are not showing anymore. I'm not sure if it is an issue with the website or with your pictures. Is there some way that you could either post the pictures again or message them to me?
Thanks for the help!
Signed,
Your Fellow Fitter
Old Jun 30, 2017 | 04:17 PM
  #37
Black3sr's Avatar
Hey Fellow Fitter. You can use this method as well and return those parts. I will be doing this before the snow flies.
Old Jul 1, 2017 | 06:36 PM
  #38
FitnForest's Avatar
Thanks, Black3SR. It looks like a decent method, although, it also seems easy to slip with the rotor (a tool I don't have) and cut a hole into the plastic cover . . . ha, so to set myself up for success, I am leaning towards the method that the OP shared.
Old Jul 2, 2017 | 05:01 AM
  #39
Black3sr's Avatar
Your welcome and good luck with the switch. I have used my Dremel a lot so not too worried about cutting through.
Old Sep 17, 2017 | 02:34 PM
  #40
Frenzal's Avatar
Finally done it this weekend.
Used the under tray from a 00 Civic, with two layers of rubber underneath. Wasn't able to connect the + cable, would not fit. Used the cable I bought, and all went smooth.
Pic of the Civic tray
