'13 fit sport running lean after intake
Old May 6, 2015 | 07:17 PM
TxMedic's Avatar
After installing a short ram intake on my girls 2013 fit sport it is throwing a CEL showing it running lean it is also shuddering a little and bogging down after shifting into second gear. Is there any way to enrich the air fuel mixture without serious mods? Seems like anything other than the factory airbox might be out of the question with this car without them.
Old May 6, 2015 | 07:31 PM
Wanderer.'s Avatar
Double check your installation. Something is wrong. I am guessing MAF sensor related.
Take everything apart and put it back together again. Pay close attention to any leaks behind the sensor or around the sensor itself that would allow unmetered air into the motor.
You don't need any additional modifications to run an intake, so something is wonky.
Old May 6, 2015 | 07:32 PM
TxMedic's Avatar
Thanks i am going to do that tonight.
Old May 6, 2015 | 11:30 PM
xxryu139xx's Avatar
what intake did u install?
Old May 6, 2015 | 11:33 PM
TxMedic's Avatar
Doing the ssr Intake. I think I figured it out maf wasn't mounted correctly.
Old May 7, 2015 | 12:59 AM
TxMedic's Avatar
Well redid everything and the car is bogging down from the start and dying. I don't know what is wrong.
Old May 7, 2015 | 05:20 AM
Myxalplyx's Avatar
Would be nice if someone in the Texas area would help TxMedic out. I'm no mechanic myself but I'd help anyone in the Delaware Valley region within reasonable distance.
Could you take a picture of your setup and post?
Old May 7, 2015 | 03:00 PM
Wanderer.'s Avatar
Hopefully you didn't break the MAF sensor. Maybe try getting some MAF cleaner in case it got dirty or oily. Also check wiring connections, etc to make sure everything is connected securely and nothing is loose or dirty.
This also sounds like a MAF problem so I would focus your attention there.
Old May 7, 2015 | 03:12 PM
xxryu139xx's Avatar
show us pictures... also is this a DIY SSR intake?
Old May 7, 2015 | 03:28 PM
TxMedic's Avatar
Well I put the stock airbox back in and it works fine. It is a diy ssr.I ordered mount for the maf I had built one myself and I think that is the problem if not then I habe no clue. I have built plenty of intakes on other cars and this one is by far the most sensitive maf I have ever worked with.
Old May 7, 2015 | 06:39 PM
xxryu139xx's Avatar
for a DIY intake, ur supposed to cut up the stock plug and use the tube where the MAF sensor plugs into. then u plug all ur piping to that.
Old May 7, 2015 | 06:43 PM
TxMedic's Avatar
Is there a step by step on how to do this. I would really like to keep my stock airbox in one piece just in case.
Old May 7, 2015 | 09:30 PM
xxryu139xx's Avatar
google search and adding fitfreak.net will help u find alot of info on this site
here are a couple of links
for GE
https://www.fitfreak.net/forums/2nd-...e-cai-sri.html
original DIY for GD since pics from above link doesnt work anymore
https://www.fitfreak.net/forums/fit-...am-intake.html
Old May 12, 2015 | 08:51 PM
TxMedic's Avatar
Ok so i got a spectre maf adapter off of amazon and installed it today and so far it is working great no cel and running great. Hopefully it stays that way.
Old May 13, 2015 | 02:02 PM
Wanderer.'s Avatar
Great! I'm glad you got it figured out!
Myxalplyx
Apr 30, 2018 06:45 PM
onetwothree
Apr 21, 2013 02:10 AM
mhopper
Mar 9, 2011 08:34 PM
bmxman
May 23, 2010 06:55 PM
bboozeman
Aug 31, 2007 09:40 PM
