Base shifter bushings and shifter cables bushings
Old Jun 30, 2018 | 05:14 PM
spookyneo's Avatar
Hey guys,
So my GE8 isn't new, but I would like to improve the shifting and remove the slugginesh to it. I'm a bit late to the party, I know ! More than 10 years ago, I had a quite modified Lancer Ralliart 2006 from which I changed the shifter base bushings to aluminium/brass ones and also the shifter cables bushings for stiffer ones (can't remember if there were brass bushings or just stiffer rubber). It made a world difference in shifting.
So I spent my afternoon looking around the web to find similar products for my GE8. And I have to be honest, I'm a bit lost. Here are my results so far :
Cable bushings
TWM Performance
Torque Solution
I believe Torque Solution would fit my needs. I am a daily driver just looking to enjoy a bit more my ride. The TWM Performance looks nice but are way more expensive.
Base shifter
Many references to H-FIT, but I believe they are out of business. I can't find them anywhere.
Anything else for a GE8 ??
I am not looking for a short shifter. I like the height of the stock shifter, only looking to stiffen it up and be more...satisfying. I read on the forums and various posts that some Acura RSX base shifter bushings are compatible with the Fit. I can't find out if if is compatible with the GE8 shifter however. If that is the case, TWM Performance and Acuity are doing base shifter bushings for the RSX. I just don't know if they are compatible with our GE8. Anyone knows ?
Thanks !
Neo.
Old Jul 2, 2018 | 03:34 PM
evilchargerfan's Avatar
I checked acuity's website and it would appear they only make shifter bushings for gk5. maybe reach out to axion directly to see if they could confirm if their kit may (or may not) work?
Old Jul 2, 2018 | 03:36 PM
*or I meant to say, reach out to acuity directly
Old Jul 2, 2018 | 05:41 PM
spookyneo's Avatar
Thanks for your reply. I did email Acuity and chat with Todd. He mentions that the cable bushings that they will probably fit the GE8, but they have nothing compatible for the base shifter bushings.
I also emailed Torque Solution and TWM. Awaiting for their reply. I still can't find H-Fit base bushings anywhere however. 😥
Old Jul 5, 2018 | 12:36 PM
Alfa38's Avatar
Looking to do the same thing. Our 2011 has 94k miles and one of the prior owners clearly drove with hand resting on the shifter as it is really sloppy (and the knob is really worn). Please post any findings and I’ll do the same.
Old Oct 27, 2019 | 11:24 AM
CodemanGK5's Avatar
I can confirm that stock GK5 bushings fit the GE8, so the acuity gk bushings should fit also.
apexanimal
Mar 27, 2012 08:51 PM
hollywood7
Dec 1, 2010 03:07 PM
No_Skillz
Feb 17, 2009 01:09 PM
xanatos
Aug 26, 2008 11:06 AM
Meangrd
Dec 13, 2006 07:42 AM
