2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Headlight Burn Out
Old May 17, 2010 | 03:55 PM
JDMxGE8's Avatar
Headlight Burn Out
It was drizzling this morning on the way to work, so I decided to turn on my headlights and fog lights. Once I came to an intersection and stopped behind an SUV, I noticed that my passenger headlight wasn't working. When I turned my headlights off, the passenger daytime-running light was working (Which uses the high beam filament). Does this mean that the low beam filament has burned out or is there an electrical probably that I can fix? Or should I just replace the bulb? Thanks in advance.
Old May 17, 2010 | 08:12 PM
FITMugen's Avatar
Yes, I would think most likely the low beam filament in the passenger headlight bulb burned out. You can remove the bulb and confirm before buying a new one.
Old May 17, 2010 | 11:47 PM
cr4zy3lgato's Avatar
had this problem a year after switching to sylvania siver star... just changed the bulb and everything was fine... so yes it's only the bulb you have to change
Old May 18, 2010 | 12:29 PM
score04w's Avatar
i had this happen only in both lights where only the high beams were working. Turns out it was a faulty switch that was shorted out and needed to be repaired. Covered under warranty throguh honda.
Rob Mangelsdorf
Jan 8, 2018 12:17 AM
mav238
Jan 14, 2015 02:59 PM
urbnzeus
Jun 1, 2009 10:26 PM
los_creeper
Aug 28, 2008 07:04 PM
anothermark
Jun 22, 2005 01:43 PM
