2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Wiring help needed -which gromet on firewall to use
Old Nov 16, 2011 | 06:02 AM
Black3sr's Avatar
I want to run a hot wire from ACC fuse to front of car for some LEDs. Any easy way to do this? I was looking at using the grommet for the hood release cable but to get to it need to remove fender inner liner - a lot of work.
Is there a constant hot wire under hood I could use?
I am adding a strip of LEDs along bottom of headlights and would like these LEDs on all the time.
Thanks
bill
Old Nov 16, 2011 | 02:56 PM
jcuecker's Avatar
There is a wiring gromet on the passanger side firewall. Its located behind the AC filter I think. You should be able to see it from inside the engine bay. This is where I routed the wire for my amp.
Old Nov 16, 2011 | 04:25 PM
Black3sr's Avatar
Thanks I will have a look. Maybe remove glove box to access inside?
Old Nov 17, 2011 | 07:40 AM
jcuecker's Avatar
I dont think you ahve to remove the glovebox but I cant remeber for sure. If your reaching up behind the glovebox it should be up and to the left.
evanphi
Fit I.C.E.
Nov 2, 2022 11:46 AM
LilPuttputt
Fit I.C.E.
Nov 15, 2019 07:36 PM
dvleucsd
Mar 20, 2014 08:27 PM
alexpan
Feb 10, 2013 06:08 AM
Stravos
Sep 11, 2009 12:18 PM
