2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Need some help ASAP
Old Aug 14, 2013 | 01:23 PM
liverpoolfcfan's Avatar
Need some help ASAP
Just received my axis styling taillights and installed them no problem, but when I went to plug all the connections back in, the one set does not work. The reverse is fine, and the large connector is fine, but the medium sized one on the axis taillight has a completely different connector. It's just a black and red wire with a weird connection. Any ideas how this hooks up to the factory connector?
Old Aug 14, 2013 | 01:45 PM
I think I am about to splice the wires and pray it works
Old Aug 14, 2013 | 02:01 PM
xxryu139xx's Avatar
mine came with adapters
Old Aug 14, 2013 | 02:04 PM
I know that's what most people said, mine just had the sockets for the reverse lights to fit into the axis lights and that's it
Old Aug 14, 2013 | 02:06 PM
I did order mine through japanparts.com though, so maybe that's were the problem is. I am really debating splicing, but I do want to screw something up with the factory wiring if does not work. It is a black wire and red wire on the axis tails and a black wire and white wire on our stock tails. What do you think?
Old Aug 14, 2013 | 02:36 PM
xxryu139xx's Avatar
I dont remember. But usually yes.
Old Aug 14, 2013 | 02:41 PM
xxryu139xx's Avatar
The usdm socket unplugs from the wire harness and u replace it with the one it came with. I dont remember if it was the brake or reverse light. Two of those usdm plugs should plug right in.
Old Aug 14, 2013 | 03:02 PM
pig_pit's Avatar
I had to splice. I pmed u. Give me text and ill take a look if u still need help
LilPuttputt
Fit I.C.E.
Nov 15, 2019 07:36 PM
Xitomatl
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 20, 2019 01:46 PM
Pjbrady
Fit I.C.E.
Mar 14, 2015 01:24 PM
ekimox
Dec 17, 2013 07:53 PM
Vash
Dec 15, 2011 03:50 AM
