2010 Head Unit with Navigation
Old Feb 19, 2010 | 09:30 PM
jeffdawgfan's Avatar
I have the 2010 Fit Sport with Navigation. I want to keep this head unit and install a small low profile subwoofer under the rear seats that is easily removable. Can anyone that has pulled this HU tell be if there is a subwoofer out jack or a pre-amp jack on back of unit. Do not want to pull if there is not one. Will have to install a amp/subwoofer combo of a existing door speaker.
Old Feb 14, 2011 | 07:18 PM
MainelyFit's Avatar
Me too....
I've been wondering the same thing....
Old Feb 15, 2011 | 09:24 PM
lashlee's Avatar
In all of the years I worked as an installer I never came across an OEM H/U with any RCA outputs. You can always add an output with an LCA or line level converter.
Old Feb 16, 2011 | 07:42 AM
MainelyFit's Avatar
What about the on/off wire for the amp? The one that is supposed to connect to the antena wire?
Any way to find a list of the colors of wires for the nav unit? I'm sure there is a ton back there.
Old Feb 16, 2011 | 09:46 PM
lashlee's Avatar
That's correct. The switched wire that you use to turn the amp on is generally the power antenna wire. You can wire it to a simple ignition wire but you run the risk of pops if the amp ever comes on without the radio on. I would grab a harness from a shop so you can use it to see what wire is what. That way you don't rely on what the net says.
rafnap
Mar 4, 2011 08:49 PM
potentialFITfan
Nov 4, 2010 06:10 PM
DENRACING
Jan 12, 2010 06:05 PM
ShannonHonda.aka.Fit
Jan 2, 2009 03:16 PM
Young Fledge
Greater Calgary Community
Jul 14, 2008 12:28 PM
