Civic Steering Wheel in a GE8?
Old Jan 18, 2011 | 02:37 PM
Leets's Avatar
One of the things I miss most about my S2000 was the glorious steering wheel. Unfortunately, the wheel in the base Fit just doesn't have the same level of feel. So I've been looking at upgrade options and figured the 8th gen Civic would be the most likely candidate for a direct swap.
I was able to find a bunch of pics of the civic and fit steering wheel/airbag set-up, and it looks like the wheel should work but the airbags are different. Does anyone have any experience with this? Searching hasn't turned up any definitive answers.
Old Jan 18, 2011 | 09:13 PM
FITMugen's Avatar
It is a direct swap except you need radio control.
Old Jan 19, 2011 | 02:14 PM
Leets's Avatar
does that mean the Fit air bag will work with the Civic wheel? Thanks
Old Jan 19, 2011 | 06:43 PM
FITMugen's Avatar
A friend of mine swapped it. It is a direct swap. I cannot tell that the airbag really work since his airbag has not deployed yet. However, plug is the same.
Old Jan 19, 2011 | 06:50 PM
bmxman's Avatar
On a side not your car insurance will be invalid unless you tell them what you have done. Even then most of them will not go for it. I would check around first since it's pretty much illegal to tamper with an airbag in all of North America. Just speaking from experience!
Old Jan 25, 2011 | 10:27 PM
jayhawker's Avatar
Have you seen the CR-Z steering wheel? That thing is bad ass.
Old Nov 13, 2011 | 04:58 PM
BlueBoogers's Avatar
Swapping it to another nearly-identical OEM wheel is not tampering anything especially when it is all OEM Honda and is plug-and-play.
Old Dec 17, 2012 | 05:27 PM
swflej1's Avatar
Any updates?
Is the Civic wheel smaller then the Fit? also are you talking about the base model or the SI?
P.S.
I know this thread is old
Old Dec 17, 2012 | 05:40 PM
I have a Civic wheel being wrapped in Alcantara. Same size, but has thumb rests. Same internals too.
Doing a pair of Civic seats soon too, also which plug right in to the airbag plugs.
Old Dec 18, 2012 | 05:37 PM
swflej1's Avatar
Thanks Blue, I thought the civic wheel was a little smaller must be the SI, but I may still look into this. Liking the thumb rest
Old Dec 19, 2012 | 05:37 AM
I didn't hold them up side-by-side, but it definitely feels the same size.
Old Dec 20, 2012 | 08:05 AM
swflej1's Avatar
When you get the Civic wheel back could you compare the two? please
Old Dec 20, 2012 | 09:08 AM
Sure. It'll be mid-January though.
Fitftw15
Feb 19, 2019 06:14 PM
counterFIT
Dec 3, 2015 09:46 PM
Tugboat6
Oct 27, 2015 08:41 AM
Jon H
Sep 26, 2014 10:39 AM
colenum
May 4, 2005 04:44 PM
