Installing aftermarket speakers in my 2010 GE8
Old Apr 27, 2011 | 02:56 PM
Java^FiT's Avatar
Hey everyone so I decided that after listening to my radio somewhat loud yesterday that i don't like the stock speakers at all... lots of cracking. So i just purchased 2 sets of speakers; components for the front and coax 2ways for the rear. Both sets are 5.25" and I will be making mdf brackets to mount them.
Interestingly enough the components I bought have built in crossovers, kinda neat and were a steal that i couldn't resist. 90 bucks total. They are by Blaupunkt, which I have had in the past and love the sound quality.
I will be posting pics of my install once I receive the speakers and start.
During this install I may also decide to hardwire my ETC using the leads off of my In dash Navi, as well as putting some sweet fabric on the doors... stay tuned
Old Apr 27, 2011 | 06:52 PM
GGPJON's Avatar
Nice. Looking forward to updates, Java.
Old Apr 27, 2011 | 07:55 PM
jdmjunkie561's Avatar
Where did u get the speakers from? I've been wanting to upgrade my speakers !!!
Old Apr 28, 2011 | 12:02 AM
Java^FiT's Avatar
i bought them from here, came out to 103 after shipping for both sets of speakers
Blaupunkt Car Stereo, Speakers, Subwoofers and Amplifiers
Old Apr 28, 2011 | 01:13 PM
britdevine's Avatar
The stock radio powering a good component set is still gonna be crappy just so you know. Might even sound worse than the stock speakers since you probably wont get any bass at all from your component set off the stock HU since its such low power.
You really need to put an amp on components to make them sing and sound really good.
Old Apr 28, 2011 | 01:29 PM
Java^FiT's Avatar
I don't have a stock HU, I am using the JVC KW-NV3HDT In-Dash Navi. I mentioned it in my OP
Old Apr 28, 2011 | 01:59 PM
britdevine's Avatar
Ok, still may not be enough juice to really make a component set sound alot better than stock.
Components just sound so much better on an amp instead of a HU, even an aftermarket HU.
Old Apr 28, 2011 | 09:13 PM
Java^FiT's Avatar
I don't plan on pushing the volume of the after market speakers, its just an improvement for crisper, clearer less crackly sound. Blaupunkt speakers are not designed for extreme volume anyhow, their optimum levels are up to the mid-high range.
An amp for these particular speaker would be overkill by every sense of the word. If i had some polks or something else higher end i would reconsider, but im not going for show quality, im going for enjoyment. But i appreciate your thoughts about it.
Old Apr 29, 2011 | 09:31 PM
Java^FiT's Avatar
Got the speakers today, removed all of the door panels after i got home and I will be cutting mdf mounting plates and running wires for the install tomorrow. I will take pics as I go along. Wiring is gonna be a pain but its necessary.
Old Apr 30, 2011 | 08:23 AM
kalani59's Avatar
that's actually completely untrue. it looks like the nominal wattage for the speakers you have is somewhere around 45 watts with a max of 200. that head unit puts out only 20 RMS watts. off deck power, you'd never get any performance out of those speakers. you really should look into getting at least a 4 x 50 amp. you'll enjoy it a LOT more.
p.s. - on a sidenote, i'm digging your fit's build progress. keep it up.
Old Apr 30, 2011 | 02:44 PM
Jamy's Avatar
Hey Java if you want an Amp for those bad boys let me know bud I may have something for you.
Old May 1, 2011 | 11:05 AM
Java^FiT's Avatar
Thanks, I am going to see how it sounds once I am done wiring it up today, I can always revisit with an amp.
I will let you know! Thanks.
Old May 1, 2011 | 06:32 PM
Java^FiT's Avatar
So i just finished installing everything, panels are back on, wiring is complete and everything cleaned. Man am i glad that is over with. It basically took me all weekend to finish this project and it came out well.
So far it sounds amazing without an external amp, so i am going to play it out for a couple more weeks to further evaluate it.
I diddnt have a chance to take too many pictures but i have a few i will post later
Old May 1, 2011 | 06:35 PM
Jamy's Avatar
Glad you like it. Weekend long projects are always fun. If decide you need an amp I believe I have an old MTX 250 watt lying around in my closest that isn't being or going to be used.
Old May 1, 2011 | 08:09 PM
Java^FiT's Avatar
Here are the shots from today.
Wiring madness...
Driver door with the 1/2" MDF adapter I made, each door got one.
Front Passenger door with component woofer installed.
These were the only shots i got during a break i took in the middle of wiring, i was too tired to take any other ones, and i was getting a little frustrated that it was taking so long, so i was just trying to finish quickly lol.
Old Jul 13, 2011 | 11:45 PM
12vltfrk's Avatar
what did you do about the two tabs on the stock speaker/mount. do you have new ones on the mdf ones?
Old Jul 14, 2011 | 12:06 AM
Java^FiT's Avatar
Didnt make new ones, if you look at this pic:
Those 4 holes for the speaker itself lined up to the threshold of the metal hole on the door so i pre-drilled past the mdf into the door metal and the screws that hold the speaker also provide 4 extra mounting points for the mdf to the door Pretty awesome non planning if you ask me haha.
Old Jul 14, 2011 | 09:41 AM
BlueBoogers's Avatar
I take it they're 5 1/4s?
I'll need to bore my doors out to run 6 3/4s up front. So many more options at that size, especially with Hybrid Audio Technologies being ten minutes from me.
Old Jul 14, 2011 | 09:59 AM
Java^FiT's Avatar
Yes I went with a smaller speaker because of the deal and the 6 1/2" ones were a little too close for comfort. I am referring to the depth of the speaker and the proximity of the magnet to the window when rolled down. You have to make sure that whatever you get is shallow enough in depth that it wont interfere with your window or you'll never be able to get it down all of the way.
You can probably loop hole this by using a thicker mdf adapter plate, and modifying the inside of the door panel to accommodate this.
Tom Spahr
Sep 22, 2015 08:30 AM
polokid69
Jan 15, 2013 04:52 PM
EMC2
Oct 28, 2010 06:05 AM
thirdeyebrian
Nov 17, 2008 03:38 PM
lilcat
Jul 2, 2007 01:14 AM
