2012/2013 Sport map lights connector?
Old Jan 13, 2013 | 12:41 AM
JHMGE8H34DC's Avatar
Question 2012/2013 Sport map lights connector?
I'm getting ready to install the map lights in my 2013 base model. The one part I don't have is the connector that plugs into the map light base's socket. I'd really prefer not to connect the wires on there with female terminals, those metal tabs are pretty thin and the proper connector would do a much better job of keeping the wires secure.
Trouble is, I can't figure out who manufacturers it, or what part # it is even if I did. I'm sure it comes with the Sport's wiring harness, which I can order for $25 (32155-TK6-A11 - WIRE, INTERIOR)...but I'd obviously prefer not to spend that much just to get a 50 cent part I can probably buy from Mouser.
Has anyone ever found one of these somewhere that fits in the map light base's socket? I'd really appreciate any info or leads anyone has on these things. Thanks!
Old Feb 2, 2013 | 07:11 AM
Got them installed last week. You can use 04321-SM4-409 CONNECTOR (3P 090 F) and 04320-SP0-A00 (SUB-CORD (0.5)
Note that the connector is a very tight fit when you plug it in, and requires a very slight modification of shaving a bit of the plastic off one side. It's obvious where it needs to be shaved down, and can be done easily with an X-Acto knife.
Hope this helps someone else looking for the same info!
gizmodog
Jun 10, 2013 10:26 PM
TwoFits
Feb 2, 2013 08:13 AM
TwoFits
Jan 31, 2013 09:33 PM
09 Blackberry Pearl Sport
Apr 26, 2010 12:55 PM
aznbigman
Jul 13, 2009 05:35 AM
