Interior Fuse Box Layout??? Help
Old Feb 21, 2019 | 05:43 PM
paul_g's Avatar
Can anyone explain how to decipher, interpret and cross-match the interior fuse box diagram with the actual interior fuse box??? I went to my local Honda and they couldn't help me.
Old Feb 21, 2019 | 06:18 PM
Goobers's Avatar
Are you confused because of the bigger black and brown(?) objects at the top row? Those are relays, the picture only has fuses. You normally don't putz with relays.
How can your local Honda not help you? Unless there was a reason they didn't want to help you...? Like for example, when they saw the two add-on wires coming off the fuses, that's a side of an aftermarket item (alarm?) and dealerships don't deal with aftermarket. That, or you pissed them off and they just wanted you out of their hair.
The add-on wire with the fuses facing down is coming from one of the fuses is coming from the 10A "LAF" (#26) whatever that is.
The add-on with fuses facing up that you can see, is coming from the 20A accessory socket (#13).
Everything is basically where the diagram indicates, row from top and column from left. The number on the fuse is the AMP it protects which. It can't be that hard to see and realize that. You must be having one humongous brain fart.
Old Feb 21, 2019 | 09:02 PM
paul_g's Avatar
Thanks Goobers, no brain fart here. Just trying to sort it out. The honda rep saw my pictures and even he said he had no idea... He stated the only way they really tell the positions of the fuses is with a tester.
The two Add A Fuse items you mention is for a dash cam (parking mode options).
Old Feb 23, 2019 | 11:28 PM
paul_g's Avatar
Again thanks Goober, once you gave me a point of reference, I was able to figure it out... Came to me in an instant. The radio (61) is buried way under the fuse box. It's actually not even part of the panel. Thanks again...
Old Feb 24, 2019 | 05:06 AM
Black3sr's Avatar
This a GK panel?
Old Feb 28, 2019 | 10:50 AM
Pyts's Avatar
I couldn't figure out that reference pic either. Honest.. Things should look like what they look like. I know this is late, but hopefully it'll help you later or somethin.
Oh, by the way, this is what the honda mechanics look at. So I assume that's why that dude couldn't help you.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 27, 2026 | 06:09 AM
Aliaksandr's Avatar
If this is still relevant to you, I found a complete description of fuses and relays with block diagrams and photographs.
https://fuseandrelay.com/honda/fit-jazz-2g.html
I think this will be useful
Plasmire
Jun 17, 2020 06:49 PM
TWGE08
Jun 10, 2009 07:54 PM
ratedz
Jan 6, 2009 08:54 AM
FitLIKEaGlove
Feb 17, 2007 11:52 AM
sLiVeRwOrM
May 13, 2006 11:02 AM
