Simple radio swap gone wrong...
Old Mar 17, 2019 | 12:30 PM
SubaruSlayer's Avatar
Okay so I am working on refurbishing my ol' machine. I've purchased a complete radio unit from the same vintage vehicle to replace mine. The part numbers and units are exactly the same, I have the radio unlock code for my unit. The goal was to swap in the other unit & get the serial number for the subsequent unlock code.
well, after the swap I now have a completely dead radio. Evem my original stock unit hates me now! They're both completely unresponsive. Dang it what did I do wrong?
I've gone as far as to test my fuse panel, all is ok there. I have no DTC's at all, either. When I plug in the replacement unit I swear I can hear a CD whizzing for a moment but that's it.
as an aspiring auto technician, I have the proper tools to physically diagnose the issue, does anyone know which direction to point me?
Old Mar 20, 2019 | 04:35 PM
vinn's Avatar
Check if there is a fuse on the radio and check ALL fuses in the box and not just the radio. Could be another fuse that might have gone out.
Old Mar 22, 2019 | 04:09 PM
56chevydan's Avatar
With everything plugged back into the radio, does anything come on when you turn the ignition on- ie the clock? Just curious if everything is dead in the radio unit or if the radio itself just isn't coming on. If the clock comes on, then double check that you're firmly pushing the on-button on the radio to start it up. You show the radio still out of the dash. I wonder if one of the screws holding the unit into the dash framework actually provides a ground to the radio? Try using a ground wire to the metal body of the radio and to a good ground around the dash area.
If both radios stopped working, you either have killed the power to the radio by blowing a fuse, or you don't have all the plug-ins plugged back into the radio or the radio isn't properly grounded. Otherwise the radio, or clock at least, should power up.
Old Mar 23, 2019 | 06:28 PM
Fiting's Avatar
Great title and photo!
Try disconnecting the battery for an hour. Install the radio. Reconnect the battery.
Old Mar 23, 2019 | 06:59 PM
Action Jackson's Avatar
Another possibility is that a wire may have been pulled or a short was created somewhere. It would seem highly unlikely given that it's a simple plug and play.
Old Mar 23, 2019 | 07:16 PM
SiXiam's Avatar
Checking the fuse is not what you want to do. You want to check the power and ground at the radio.
Old Mar 25, 2019 | 04:55 PM
Figured it out!
What happened was, when both units were removed from the car, they were both pried to hard on & it just barely lost connection with the radio. I installed it without a bracket & was about to give up. I noticed the stereo was on but the backlight wasnt.
I ended up reinstalling everything and had a dead radio again. So I found the culprit. I've reinstalled the faceplate to the radio & left the bracket loose.
Everything is great now, oddly enough.
Old Mar 26, 2019 | 09:25 AM
carotman's Avatar
Check the power at the radio connector (car side) and make sure the 12V constant, 12V switched and ground are correct.
yellow wolf
Oct 24, 2015 05:51 PM
Fit freak242
Nov 6, 2013 10:44 PM
damoaten
Feb 28, 2013 11:09 AM
Ursenay
Aug 29, 2012 06:56 AM
xorbe
May 5, 2006 12:45 PM
