Want to have HD radio - what are my options?
Old Aug 28, 2012 | 09:13 PM
Ursenay's Avatar
I know, HD radio is kind of passe, but our local NPR station broadcasts a lot of great stuff on their HD signal that you can't get anywhere else (BBC, etc). Since the radio is integrated into the dash on the Fit (base, 2010), do I have any other options? Is there any kind of an under-dash adapter that will work with this radio?
Tks!
Ursenay
Old Aug 28, 2012 | 09:32 PM
specboy's Avatar
your best bet is to get an aftermarket head unit. it'll have bluetooth, HD Radio, and many other features as well as much better quality sound than the stock Head Unit. It'll likely only be a small percentage more than buying an HD Radio Add-On.
What's your Budget?
Check out Crutchfield.com for Head Units. They provide all of the adapters and dash replacement pieces to make a radio fit(they also include instructions and are authorized resellers of everything they sell so manufacturer's warranties aren't voided like many other places). PM me if you go this route as I'll give you a referral code (which should get you a few bucks off - but I think you have to spend $200 or more)
Edit - this one has HD Radio, Bluetooth, and is similar to a radio I am looking at (I Don't need HD Radio but want android Control)
http://www.crutchfield.com/p_105KWHR...T.html?tp=5684
~SB
Old Aug 28, 2012 | 10:25 PM
lowkeymods's Avatar
I don't know other options but for under $300, you can get HD, so many features, and MUCH better sound w/ an aftermarket unit, as noted above. I'm glad I did it.
Old Aug 29, 2012 | 12:07 AM
Ursenay's Avatar
@specboy - thanks for that info. So the unit you linked can be made to totally replace the factory radio and the dash mount?? Assume that's the "head unit" you're talking about (sorry, I'm new to the Fit community, so I don't know the lingo!)??
Ursenay
Old Aug 29, 2012 | 12:24 AM
lowkeymods's Avatar
If you go w/ Crutchfield yes, but it doesn't match perfectly. There are threads here to help you adapt the OEM navi dash to a new hu, which does match perfectly. I went w/ the latter option, and did the JDM hazzard button while in there.
Old Aug 29, 2012 | 12:26 AM
^That looks super nice. GD guys need an option like that
Old Aug 29, 2012 | 06:56 AM
specboy's Avatar
Ursenay
Headunit is the Term for the Main Car stereo and there are two general Types, Single Din & Double Din. A Double-Din is what is pictured above and a Single Din is half as tall as the one shown. "DIN" is the standard for car stereo size manufacturers. Both Single & Double Din stereos will fit and Crutchfield will supply you with an in-dash pocket for above or below the Head Unit (HU) for Single Din Stereos. A Double-Din unit will fill out the dash a little more nicely and usually has larger knobs and a bigger display (simply as it has more room). Crutchfield will also supply you with the wiring harness that adapts the wiring from the HU Manufacturer's setup to Honda's configuration making it a plug & Play solution (albeit you will need to match up and crimp or solder the wiring harnesses together - this is usually a color for color match and worse case, you match the writing on the one wire harness to the wire on the writing in the manual of the stereo)
Picture of a wiring harness: Receiver Wire Harness For select 1998-up Honda, Acura, and Suzuki vehicles at Crutchfield.com
My longer "Drawn-out" explanation may make it sound a bit complicated but it really is easy and crutchfield's tech support is free and well experienced. if you are new at this and have never soldered, I'd go with a crimp tool and some butt splices which make it even easier (available at any hardware store). if you have a friend that is decent with electronics, even better. We're also always here for help and there are a number of DIY (Do it yourself) installs with pictures that people have done on this board.
~SB
yellow wolf
Oct 24, 2015 05:51 PM
fittr9
Jan 13, 2011 05:24 PM
IN2TURBOS
Feb 1, 2010 06:32 PM
Crawly
May 9, 2008 11:17 PM
xorbe
May 5, 2006 12:45 PM
