AC Compressor Clutch Assembly Replacement
Old Mar 24, 2019 | 04:56 PM
sewoodfin's Avatar
Hey everyone, got a 2010 Sport with no AC compression. When I turn the AC on, I get the what sounds like metal spinning on metal, so I'm assuming its the clutch. Anyone more mechanically inclined think this sounds right? As well, has anyone attempted this repair job on their own and how did it go for you? I live in Texas and with summer just around the corner, I need to nip this in the butt PRONTO.
Thanks in advance.
Old Mar 24, 2019 | 06:10 PM
cutsheal5's Avatar
Sounds like your front plate is worn out. It's held in with one nut. The nut can be removed with a 14mm socket, you can't get the parts at Honda very cheap but there's lots of aftermarket versions available on eBay for $50.00 or so. If it's engaging sounds like everything is working just all the material is Burnt off. It's a really easy job I had mine off last week because it siezed up.
Old Mar 24, 2019 | 06:52 PM
sewoodfin's Avatar
Unfortunately it doesn't seem to be engaging at all. Do you buy chance have a part number or ebay link for the replacement part? And how easy was it to get to?
Old Mar 24, 2019 | 07:10 PM
cutsheal5's Avatar
https://www.ebay.ca/itm/AC-Compressor-clutch-Front-Plate-Fit-Honda-CIVIC-1-8-Liter-2009-2010-2011-Hub/292912761740?epid=4027877213&hash=item4432f60b8c:g :35wAAOSwsTVapyf2
bobvila
Jun 9, 2021 07:00 AM
Jeff8bass
Jun 7, 2021 04:20 PM
iandunham
Dec 1, 2019 05:09 PM
rickame
Sep 26, 2019 09:20 PM
laszlosujj
Jun 7, 2017 08:30 AM
