Honda fit 2008 starting issues
Old Apr 8, 2019 | 10:41 AM
Honda fit owner's Avatar
Question Honda fit 2008 starting issues
Hi,
I have 2008 Honda fit sports version 138K miles. From lats couple of days i am facing problem with starting my car, after ignition off and removing keys car doesn't start and everything becomes dead, lights, keys less fob all dead but when i use jump start it works. i went to store and checked my battery and alternator everything is fine. also when i do ignition off fuel guage also behaves abnormally, sometime it shows fuel meter even after ignition off.
please help me understand whats wrong with the car.
Thanks.
Old Apr 8, 2019 | 11:11 AM
ChuckDustin's Avatar
Look at your car battery terminals. Are they corroded? Are the connections tight?
If they are corroded, take the battery cables off and clean the terminals with a brush and some baking soda.
If they are loose, tighten the terminals up and see if that helps.
If neither of those work, then we can try a few other options.
Old Apr 8, 2019 | 11:13 AM
Thanks, I went to local shop and they checked battery and Alternator both looks good.
Old Apr 8, 2019 | 11:18 AM
Did they actually check the connections of your battery? Or only the battery itself?
Old Apr 8, 2019 | 11:19 AM
yes I did check for battery and it looks good.
Millartime160277
Dec 26, 2019 12:16 PM
genslay
Dec 21, 2017 03:44 AM
alicia454
Dec 14, 2013 11:59 AM
N.O.R.M
Mar 31, 2013 12:23 AM
AWDturbo
Apr 27, 2009 11:32 PM
