Po301
Old Jun 25, 2019 | 09:34 PM
Beriah's Avatar
Po301
So I got the code for cylinder 1 misfire, I replace spark plug, and ignition coil, still have error code, wondering what I should check next (13 sport if it matters)? The car has around 130,000 miles (car belongs to my wife so not certain) so was thinking I might do a little of everything while I am at it, but need to first figure out the misfire. So any advice on what could be the next potential issue would be great!
Thanks
Old Jun 26, 2019 | 10:28 PM
GolNat's Avatar
You did reset the ECU after you replaced the parts correct?
Old Jun 27, 2019 | 07:30 AM
Beriah's Avatar
I did try to clear it, still on
Old Jun 27, 2019 | 07:55 AM
spike55_bmw's Avatar
I'm not trying to be critical but thinking out loud:
1.) PO301 - did you do the proper cylinder?
2.) If you did do the proper cylinder, is everything hooked up right, and not lose again?
3.) If you are replacing one spark plug, why not replace all 4 since all have 110,000 miles on them (recommended replace interval)? Great time to check to see if any are lose and possibly producing / will soon produce a misfire code.
4.) Only after replacing all 4 plugs, would I consider changing the coil pack if I continued to get the PO301 code.
Old Jun 27, 2019 | 09:44 AM
evilchargerfan's Avatar
swap coil 1 with coil 2 .... does the misfire cel move to cyl 2?
Old Jun 27, 2019 | 10:04 AM
Fiting's Avatar
What was condition of old spark plug & coil? How was the spark plug gap size, tip color and condition, etc. Did coil look burnt, deformed, oily or new? Did you check wiring to coil for visible damage?
Cylinder 1 is closest to accessory belt.
Did you buy new coil from Honda? Non-OEM coils have high failure rates but the OEM ones can be DOA also.
Old Jul 1, 2019 | 04:37 PM
Beriah's Avatar
I did use OEM coils, tried swapping coils, adjusted valves, nothing helped. When I put everything back together I got even more errors. These are the list of new codes that came up
p2185
p0453
p0301
p2183
I am at a total loss on what to do. I am going to buy a new ECT sensor in hopes that helps.
Old Jul 3, 2019 | 09:11 AM
Did codes go away with driving or resetting? We had a VW that required disconnecting both battery cables at the battery and touching the disconnected cable ends together (DO NOT HAVE THE BATTERY CONNECTED TO CAR IN ANY WAY WHEN DOING THIS) to erase the memory.
Old Jul 3, 2019 | 05:29 PM
Beriah's Avatar
Well I gave in and took it to the dealer, and while I believe people on here are far smarter than I am, I don’t believe we would have ever diagnosed this problem via a forum! Turns out a mouse decided to chew up some wiring under the car, to the tune of $410! They repaired the wiring, cleared codes and all good.
Old Jul 4, 2019 | 05:50 PM
Yes, mice do a lot of damage. So far they have only 'spoiled' our cabin air filters in a Civic and the FIT. Always amazing how fast they work.
angus.mundy
Dec 15, 2024 12:16 AM
Globalksp
Jun 20, 2021 11:36 PM
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
TheTracker2018
Apr 6, 2018 06:24 PM
Tuan
Oct 2, 2009 06:41 PM
