P0303 code - misfire on 3rd cylinder after 52k milees
Old Oct 2, 2009 | 12:44 AM
Tuan's Avatar
After a search, i found only one other post regarding this OBDII code. It sounds like it's very uncommon. I've never seen this before in the newer cars ever since the dwell/rotor and single coil are obsolete.
I haven't had time to investigate the problem, but I will follow up after inspecting the cables and spark plugs.
Old Oct 2, 2009 | 08:29 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
there is no cables. just coils over plugs.
change your plugs and see what happens first.
if it still happens you have a bad coil.
Old Oct 2, 2009 | 06:41 PM
Krizz's Avatar
You might want to read through this thread
https://www.fitfreak.net/forums/fit-...d-stutter.html
If I recall, they don't ever post the actual code, but it does turn out to be the coils causing misfiring and stutters, if you can make it to page 4.
A number of people seem to be having the problem, not sure, but I think they all were GD owners.
Good luck
EDIT - Bernardi is showing slightly different part #'s for the GD's & the GE's coils, also, the GE's have an insulator added, I wonder if heat was the cause of the coil problems in the GD's?
angus.mundy
Dec 15, 2024 12:16 AM
Globalksp
Jun 20, 2021 11:36 PM
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
TheTracker2018
Apr 6, 2018 06:24 PM
Globalksp
Nov 4, 2017 06:46 PM
