ABS, VSA, E-Brake Warning Lighted
Old Sep 22, 2019 | 11:44 PM
SA6YEuro's Avatar
Hi guys,
I wonder if you have encountered this issue. All 3 warning lights came on after driving around a short while in my Auto GE8 and it disappears after shutting off and restarting the car.
Used a diagnostic tool and got a 121-11 error code. Checked the DTC and it says VSA Solenoid Valve Malfunction. Further checking refers to Right-Front or Left-Rear Valve Regulator.
Is the Valve Regulator part of the ABS pump as in the metal part with the attached metal hoses or the plastic module. The diagram I searched online is some what incomplete. What is the cause of this and do I need to change the entire unit to solve this issue.
Thanks.
Old Sep 25, 2019 | 11:38 AM
SA6YEuro's Avatar
Anyone can help me on this? Would really appreciate if you know how to go about this issue. Thanks
Old Sep 25, 2019 | 01:51 PM
Pyts's Avatar
Give a minute n I'll look up some info. Your fit is USDM and made between 09 and 12, right?
Old Sep 25, 2019 | 08:02 PM
SA6YEuro's Avatar
Mine is a 2013 JDM but is very similar with the USDM LX. It's the same L15a7 under the hood. Appreciate it mate.
Old Sep 26, 2019 | 06:06 PM
Pyts's Avatar
Post
Originally Posted by SA6YEuro
Hi guys,
Thanks.
I'm not happy about what I was able to gather for you in so much as the VSA is referred to as a unit and I have no knowledge of or material reference for repairing it, only replacement.
Hows that for a wordy sentence?
I'll attach documentation of my findings.
Switching to hip-fire. We both know well enough what a valve is, what regulates said valve however should be an electronic control module, or plastic thingy. If you could find a replacement I do believe you would still have to go through honda to program and update it's software since it has it's own brain and retains codes even when disconnected from the battery.
The troubleshooting procedure I found for a 2012 USDM (which supposedly varies from previous model years, though I'm unsure as to how) suggested first clearing the code and waiting for it to reoccur. Second step was to have the software updated. Though personally I can't imagine why this would be necessary, it may be relevant to your situation. This procedure to my knowledge would require use of the Honda Diagnostic System tool. After that, unit replacement was recommended.
Tell me your thoughts and we'll go from there I suppose. I do have more reference material for the VSA system, spanning about 200 pages, so we aren't at a stopping point yet.
Apologies for the late response.
File Type: pdf
Old Sep 28, 2019 | 05:52 AM
SA6YEuro's Avatar
Apologies for the late reply. Thanks for the help and pointers. I truly appreciate your assistance. I have just flushed out the brake fluid as it didn't look promising at all. Was quite murky and no longer clear as it used to. Hope this can solve this issue. Then I ll clear the error code and we ll see how it goes before I decide to replace the entire module.
Old Sep 28, 2019 | 10:16 AM
Pyts's Avatar
I like that idea and hope it works. It seems questionable to assume that old fluid could cause issue, unless water was introduced or level was low. Ah, I guess the case of hydraulic fluid v. time is a simple fight against corrosion/sludge (the result of mysterious exhausted additives). Crossing fingers for yuh.
Old Apr 29, 2020 | 09:18 AM
SA6YEuro's Avatar
Just to share with everyone the final outcome. Well after trying so many possible ways to solve this issue, in the end I got me a junkyard unit and replaced it. And it solved the problem. VSA and ABS is back to normal.
Old Apr 29, 2020 | 12:00 PM
56chevydan's Avatar
It's nice to see someone asking for help on this forum following through and posting a final outcome on a repair. This helps everyone on the forum learn what steps in a repair solved the issue.
Old Apr 29, 2020 | 01:49 PM
SA6YEuro's Avatar
Wanted to update everyone as soon as I can but didn't manage to find the time to search for the parts until recently. Hopefully this would be helpful to others one day.
Old Dec 24, 2020 | 11:42 AM
femioloks's Avatar
Please kindly give the complete document, I want to update the abs module of my car
Old Dec 25, 2020 | 08:39 PM
fit09's Avatar
So no reprogramming of the ABS assembly was required? Also how did you purge air from the replacement module ?
Old Dec 27, 2020 | 01:56 PM
Pyts's Avatar
To femioloks, I can only upload a couple pages from the Bishko service manual at a time. It's useful for troubleshooting specific faults, but the transfer of some 200 pages here would be a bit difficult to organize. If there's a specific thing, I can put it up for you when I get home. If yuh want the full document however, it can be obtained quite reasonably in disc form from amazon. I've got a link for you right
here here
Old Feb 24, 2021 | 06:19 AM
Melvin Ng's Avatar
Hi able to ask what u replace??
phoenity
Oct 20, 2016 05:39 PM
phoenity
Sep 22, 2015 04:03 PM
jimsmith101
Jan 11, 2014 04:26 PM
Trying to Help
Oct 10, 2005 12:32 AM
Glenn Richmond
May 4, 2005 04:44 PM
