Starting troubles
Old Oct 29, 2019 | 06:51 PM
The_Hoonda_fit's Avatar
Starting troubles
My car was working fine yesterday, but now it’s not wanting to start. The battery had 11.8 volts and even jumping it didn’t help. And my battery is fairly new. It’s making a clicking sound but not just one click, it’s several clicks. Quick clicks.
we thought it was the starter because the battery had that high of a voltage but now we’re thinking it is the battery because the battery normally has 12 volts or even 13. Help?
Old Oct 29, 2019 | 07:32 PM
Red 05's Avatar
Either something is being left on and draining, your battery is defective or it's a charge issue
Old Oct 31, 2019 | 09:10 PM
dll932's Avatar
If it's a top post battery, clean off the top of it. Electrolyte can get on there and actually short across the plastic. Also check to see if the ground connection is clean and tight-bad grounds can cause all kinds of problems. If it's not a sealed battery, it may need more distilled water in the cells. How old is the battery?
EXT
Jul 29, 2013 10:53 AM
Remco
May 4, 2005 11:16 AM
Remco
Remco
piclistguy@yahoo.com
