Race Ramps
Old Dec 13, 2019 | 11:09 AM
usert_l's Avatar
Race Ramps
Anyone here heard of or has experience with these ramps? I went ahead and bought a set from Summit racing:
https://www.summitracing.com/parts/bti-rr-56/
I need something like this because my Fit is lowered now and doing any oil or fluid changes is a big hassle because my jack is not low enough or long enough to go under the center jack point behind the engine/transmission. It can't even go under the jack points behind the tires.
I hope these ramps will also save a little bit of time doing oil changes. I do feel a little nervous about the foam material they're made out of. I will make sure to use separate jack stands once the car is up for extra protection.
Old Dec 13, 2019 | 11:24 AM
2Rismo2's Avatar
Geez that's expensive for a ramp. Have you consider making one yourself? Some 2x6 stacked into a ramp configuration would be a lot cheaper, albeit heavy.
I just use a plastic ramp I bought from harbor freight. It was probably less than $50 and had the capacity to hold up my old SUV. That one you linked is rated for 3k pounds which to me doesn't leave much wiggle room when the Fit weighs about 2700lbs.
Old Dec 13, 2019 | 12:27 PM
Frenzal's Avatar
Just drive on a pair of 2x6, then use a jack. Much easier...
(if it is still too low, use two of them on top of each other, with a little offset)
Old Dec 13, 2019 | 01:01 PM
usert_l's Avatar
These ramps won't be used to support the whole car. Just the two front wheels. My guess is the front end is less than that ... maybe around 1700 lbs or so? Should be well under the 3000 lb rating?
Yea they are expensive but I want to try them out. Should have them delivered in 3 weeks.
Old Dec 13, 2019 | 01:13 PM
2Rismo2's Avatar
fair enough, you're money to spend...
Old Dec 13, 2019 | 03:34 PM
evilchargerfan's Avatar
I use these:
worked fantastic for a car with low ground clearance
(here is my old car, held up its heavy weight, just fine and dandy)
Old Dec 13, 2019 | 08:41 PM
GolNat's Avatar
So you had a car featured on Super Street and failed to mention this at some point during your FitFreak posts?!?
Dat stance tho <3
I like my DIY wood ramps. Heavy AF but they get the job done.
Old Dec 16, 2019 | 01:58 PM
Dat stance tho <3
I may have posted that car once or twice, lol. I do miss the "good ol days" when stance was IN and the car scene was fun and less about "likes" or "subscribe to my channel"
those ramps look well built! ever driven on those... and driven too far forward? I can tell ya .... its NO FUN ... ask me how I know!
Old Dec 16, 2019 | 04:41 PM
GolNat's Avatar
Lol, I must have missed it. I would say stance is still in but it gets a lot of hate and I don't understand why. I might not stance my car but that doesn't mean I can't appreciate a well stanced car. There are lot's of ways to build a car.
I was watching a YouTube video and they mentioned a site called Wheel Well so I checked it out. I was disappointed to see that is was more of a contest then a community. At least from my look around the website.
No, I have not done that but do have nightmares of it happening. I like that these ramps have steps so I can count them as I go up. 4 bumps and I am at the correct level.
Old Dec 16, 2019 | 04:50 PM
GeneralLee86's Avatar
Yes I've done it too but don't remember whether I did it with my Cavalier or the Fit! It didn't do anything to the car but did destroy the ramp it broke in half! So I still have them but next time will buy steel ones which are the ones I like better!
Old Dec 24, 2019 | 08:10 PM
usert_l's Avatar
Got them delivered today. On my weight scale each piece is about 10 lbs. Made in USA.
I'll test it out soon on my Fit and a Rav-4, which is heavier.
Here are a couple pictures I took.
Old Jan 1, 2020 | 05:10 AM
windsunh2o's Avatar
Have you had a chance to test them out? 10 lbs a piece is impressive for a lightweight lifting option. Interested to see how they perform for you...
Old Jan 1, 2020 | 03:09 PM
usert_l's Avatar
Fit and Rav-4 got on top of them without any problem. These ramps give me an 8 inch lift.
Old Jan 2, 2020 | 09:01 AM
GolNat's Avatar
Nice! Looks like a good purchase. I really enjoy using ramps over jack stands.
SilverEX15
Sep 26, 2017 08:55 PM
Thorzdad
20
Dec 16, 2011 12:38 PM
secondspassed
Dec 28, 2009 04:50 PM
halfmoonclip
Apr 10, 2009 09:50 AM
GD3_Wagoon
Nov 11, 2008 12:25 PM
