Need help, water in gas tank!
Old Dec 28, 2019 | 05:34 PM
Jiangqiu Shen's Avatar
Yesterday, I filled the gas and forgot to close it, and I went to an auto washing house for cleaning. I think there may be a lot of water in my gas tank. What can I do?
Old Dec 28, 2019 | 06:07 PM
spike55_bmw's Avatar
Did you drive the car home from the car wash? If, yes, then you're good for now but if the temperatures drop below freezing, you're screwed.
I would go to the car parts store (Advance Auto, Auto Zone, O'Reilly's, or even Walmart, etc) and get some "Heat" or other brand of 'gas line antifreeze', which has methanol alcohol in it. This will chemically attach itself to the water and to the gasoline, and it'll get burned as you use the gasoline.
Again, this is an important thing to address ASAP before temps significantly drop and the water freezes in the gas line and then you're done until it gets thawed out (heated garage) and water-alcohol-gasoline mixture is used up..
Old Dec 30, 2019 | 08:13 PM
Kyle05STi's Avatar
Yep, methanol is your friend if there's water in the fuel.
Go for the standard HEET in yellow bottles, it's basically pure methanol (99% iirc). The red, ISO-HEET bottle are 98.5ish% Isopropyl alcohol. It's not recommended to use more than one bottle in 10 gallons of fuel, but it should be safe to run 1 bottle per tank through multiple consecutive tanks.
Old Dec 31, 2019 | 10:06 PM
SiXiam's Avatar
With that much possible water I'd pump it out of the tank or drain it from the fuel line.
Old Jan 1, 2020 | 07:33 PM
steve37's Avatar
How far did you get?
Jakob Mend
May 15, 2019 01:32 PM
BankWalker
May 5, 2019 09:55 PM
cavernap
Aug 13, 2018 02:41 AM
champagnefit08
Dec 15, 2010 09:50 PM
chibitul
Sep 5, 2005 12:33 AM
