My Fit 2009 used to get 30mpg now it's averaging 25-27mpg
Old Jan 4, 2020 | 06:13 PM
frogeer's Avatar
It's at 135k now. I've changed out all the air filters, the spark plugs still look good, and I added fuel injectors into it already. What could be wrong with my fit? Is it just old age? Also the last time I did an oil change I used 5w-30 instead of 5w-20 (my mechanic told me to do that due to the wearing of the engine pistons, they need a thicker oil).
Old Jan 4, 2020 | 07:50 PM
steve37's Avatar
Tire pressure?
Old Jan 4, 2020 | 08:22 PM
GolNat's Avatar
Has your commute changed? Do you have winter blend gas in CA? It’s been cooler out so has the car been idling more? Tire pressure? 5w-20 is a more fuel efficient blend then 5w-30.
Old Jan 4, 2020 | 11:09 PM
GE82010's Avatar
also check your air filter if its dirty mine was doing the same now im back at 34 mpg
Old Jan 5, 2020 | 12:09 AM
frogeer's Avatar
It might be the 5w-30 then because I notice this started during the summer too. Probably around the time I changed my oil to 5w-30. I'll monitor it from here because I just did another oil change and I switched it back to 5w-20.
Old Jan 5, 2020 | 12:10 AM
frogeer's Avatar
Yup, changed all my air filters.
frogeer's Avatar
Originally Posted by steve37
Tire pressure?
I doubt it's that. My tire pressures are always at normal.
Old Jan 5, 2020 | 12:13 AM
GE82010's Avatar
have you cleaned the air sensor? and around the throttle could be dirty also i clean my egr as well
Old Jan 5, 2020 | 12:41 AM
SiXiam's Avatar
How old are the Ignition Coils?
Old Jan 5, 2020 | 01:14 AM
frogeer's Avatar
I never replaced it.
Old Jan 5, 2020 | 01:21 AM
SiXiam's Avatar
Could be part of the issue. Often the plugs will last longer than the coils.
Old Jan 6, 2020 | 12:06 PM
jbyron's Avatar
Same thing happened to me, didn't think much of it. I am at 62k miles. Finally got a misfire code for cylinder 2, turned out the spark plug in cylinder 2 was backed out and cylinder 3 was halfway out. Changed all my coil packs, plugs, and did a valve adjustment and now I'm averaging 35mpg my last week of driving. Car is smoother and peppier as well. Check your plugs and coil packs, it took the plugs backing all the way out to throw a code, yours may be loose but not enough to throw a code just loose enough to bork your mpg.
Old Jan 6, 2020 | 12:40 PM
GE82010's Avatar
im at 200k and i haven't adjusted my valves im too scared to do it myself im in socal
Old Jan 6, 2020 | 01:56 PM
Red 05's Avatar
Its not a scary job, just a methodical job. I'll link a video at the bottom on a DIY. Requires very basic tools and a replacement valve cover gasket, which Honda wants about $9 for. But, a valve adjustment isn't going to net you any significant mileage increase. Maybe 1 mpg if they're way off but you'd be lucky to see that big a jump.
InternDoc
Aug 2, 2014 06:28 PM
wackyflik
May 21, 2014 04:07 AM
T-Fit
Jul 18, 2012 03:24 AM
teamkitty
Jan 29, 2010 09:44 AM
pb and h
Jun 8, 2008 12:18 PM
