Pre-mix fuel in the fit?
Old Jan 27, 2010 | 02:00 PM
teamkitty's Avatar
Hypothetically, what do you think would happen if someone were to fill a near-empty tank with a 2-gallon container of 50:1 pre-mix fuel and oil into their fit?
Old Jan 27, 2010 | 02:18 PM
Steve244's Avatar
Not much. Some oil gets by the rings and is burned in all cars. Might foul the plugs if you ran it often. Smoke a bit. Just a guess.
Here are some rotary guys that seem to think it helps to oil up their wankels.
Old Jan 27, 2010 | 02:27 PM
fitisbamf's Avatar
u can run premix in a rotory but u need to take out the thing that causes it to shoot oil ino the rotor housing.... i used to own an fc....
Old Jan 27, 2010 | 04:23 PM
Schadenfreude's Avatar
It might smoke a little. In the long term it might not be good for plugs, oxygen sensor, cat.
Is this REALLY a hypothetical question?
Old Jan 27, 2010 | 05:09 PM
umop-apisdn's Avatar
Oil metering pump.
Old Jan 27, 2010 | 05:27 PM
HONDAMATIC's Avatar
sounds like a mistake to me
Old Jan 27, 2010 | 06:44 PM
clay7160's Avatar
it would smoke alot...but i would fill the tank up with gas, and maybe put some injector cleaner in as well...then as soon as i would use a little gas, i would keep the tank full..to dilute the oil, until it quit smoking....we used to have to put premixed oil in our 4 stroke dirt bikes, when we would run out of regular gas, for some reason, our two stroke friends would burn less than us..
Old Jan 27, 2010 | 06:49 PM
jadr09fit's Avatar
I'd put in a gallon with one fillup and another gallon at another fillup. Then it would be at least 300:1, or just enough to lube everything up nicely without killing the sensors or the cat.
Or top off your tank with a gallon after you've driven ~25-30 miles, then get a buddy to do the same.
If you're reasonable with the amount you put in, it won't have any effect on your car.
Old Jan 28, 2010 | 02:30 AM
HONDAMATIC's Avatar
but WHY???????????
Old Jan 28, 2010 | 10:34 AM
mike2100's Avatar
Originally Posted by HONDAMATIC
but WHY???????????
exactly, there is no sensible reason to do this
Old Jan 28, 2010 | 10:47 AM
Steve244's Avatar
Ran out of gas and all you had handy was a tank for the boat?
Old Jan 28, 2010 | 11:35 AM
Black3sr's Avatar
I suspect it is not a hypothetical question but has happened and now the Fit is not quite Fitting along.
Maybe injector cleaner might help? I have no idea.
Old Jan 28, 2010 | 12:06 PM
Steve244's Avatar
I think bad gas (it was for that boat they got rid of 5 years ago) is more likely than the 2cycle marine oil causing a problem at 50:1.
Maybe teamkitty is stranded on a desert island with a Fit and a can of boat gas.
Old Jan 28, 2010 | 03:01 PM
teamkitty's Avatar
I was actually going to try cutting the grass with my fit (custom blade attachment fitted to a power take off unit) and wanted to see if i could use the same gas for all of my power equipment.
Old Jan 28, 2010 | 04:22 PM
spreadhead's Avatar
At the end of mowing season I pour the remainder of my mixed gasoline in a full tank (less than 1/2 gallon) to get rid of it in an environmentally friendly fashion. I don't think this small amount of oil has any adverse effect. If I wanted to add oil to my fuel on a regular basis (I don't), I would use ::Marvel Mystery Oil:: .
Old Jan 28, 2010 | 05:02 PM
teamkitty's Avatar
Thank you spreadhead, that is actually the same reason I asked.
I had actually already done this and posted after the fact to see what others thought and to get a kick out of what I assumed were going to be the typically over-reactive expert opinions (your engine's gonna blow!). I was wrong, as most of you predicted exactly what happened to my fit after adding the premix before I created this post: absolutely nothing.
Old Jan 28, 2010 | 06:09 PM
HONDAMATIC's Avatar
cant your just put some sta-bil in the mower etc?
if i was gonna pour it in a car i would do it in the beater
Old Jan 28, 2010 | 06:59 PM
mahout's Avatar
If you then filled the tank with gasoline, not a thing. you might see a little smoke in your exhaust but no harm will be done. A 50:1 mixture diluted even futher by gasoline is not a problem.
Old Jan 29, 2010 | 09:44 AM
spreadhead's Avatar
I don't drive "beaters".
robs
Jan 28, 2019 05:45 PM
mitchl3000
Aug 8, 2018 05:08 PM
Margelous
Jul 20, 2010 11:42 AM
randomracer
Feb 5, 2009 08:54 PM
boon4376
Aug 8, 2008 10:27 AM
