Overfill antifreeze reservoir?
Old Jan 29, 2020 | 03:15 AM
JerryHughes's Avatar
Hi all,
Hey, after changing antifreeze fluid, I had a little fluid leftover so instead of storing it, I poured the rest into the plastic tank reservoir. Well, instead of keeping that tank level between the high and low levels that are marked on that tank, I added more. The "high mark" level is about six inches or so below the top of that plastic reservoir but now the fluid is within about three inches from the top of the tank. Anyone know if that will cause any problems? Thanks for your input.
Old Jan 29, 2020 | 05:16 AM
Frenzal's Avatar
It will overflow when the engine gets hotter. Low mark on the reservoir should be with cool engine, high mark should be when engine is hot.
Old Jan 29, 2020 | 08:28 AM
Ahhhhhhh, that's the reason I "lost" anti-freeze in the past when I overfilled that tank! Duh. Thanks for your post. I will empty the extra today.
domromer
Feb 19, 2019 06:37 PM
CyclingFit
Feb 11, 2019 05:08 PM
michaelglasscook
Jan 16, 2017 12:14 PM
kaede1337
Jul 31, 2016 05:22 PM
xander
Feb 2, 2009 01:50 PM
