Engine Light Flashing + Loss of engine power
Old Feb 20, 2020 | 04:03 PM
hypnogorium's Avatar
I am having an intermittent problem , where the engine light flashes and the car won't go more than 20 MPH . If I pull over , shut off the car and restart the problem goes away. It's happened about 4 times now . Seems to be on cold days, below freezing and on first start of the day. Any help would be great.
Old Feb 20, 2020 | 07:48 PM
beardedGTI's Avatar
Would help to plug in an ODB reader and know what code it’s throwing. My initial guess is something MAF related based on your description alone, but really could be anything.
Old Feb 20, 2020 | 10:06 PM
I tried to read the codes but for some reason a link error keeps coming up on my scanner .
Old Feb 20, 2020 | 10:48 PM
fujisawa's Avatar
I’m going to go for low battery. If you run the car to let the alternator charge it up a bit does that help? Keep in mind that low voltage can throw bad codes or other odd OBD behavior. The maf sensor already mentioned is definitely not a bad guess too.
yogs
Jun 1, 2025 02:46 PM
phenoyz
Nov 11, 2016 01:34 AM
phenoyz
Apr 14, 2015 10:16 AM
bjvalencia
Jan 30, 2012 09:26 PM
hydrogennine
Sep 7, 2011 11:59 PM
