HELP - Recirculation/Fresh Air Flapper Door Stuck (2011 Fit Sport)
Old Mar 15, 2020 | 12:36 PM
Yoyojomo's Avatar
I'm having an issue with the recirculation/fresh air flapper door on my 2011 Honda Fit Sport, where it absolutely will not shut all the way (i.e. won't switch fully to recirculate mode). Here is a video of what's going on:
Does anyone have any idea what to do? I've tried manually pushing the plastic pieces, moving them around, pushing the switch hard toward recirculate mode (without breaking it obviously). Nothing works. I thought this may have happened when I changed my cabin air filter, but no matter what I do, it will not fully engage recirculate mode. Any ideas?
Old Mar 16, 2020 | 05:54 AM
Goobers's Avatar
If you're necro a post, try to stick to it. Its pretty annoying and off-putting (ie, some folks will ignore you because of it) when you dig up or post multiple times on the same subject.
That said, let's stick to the other one since you brought it up. https://www.fitfreak.net/forums/2nd-...ml#post1444084
Old Mar 16, 2020 | 09:55 AM
Yoyojomo's Avatar
Here we go again. Are you trying to get me to leave? I gladly will, if this is what this community is like. The other post was similar, but not exact to my issue, so I posted there to see if that specific user (or the users in that thread) had anything to add to their thread that was similar to mine, in addition to posting my own issue. Once again, you assumed I was being an idiot, then you responded.
Anyone else on this forum: is this the common experience of new users? Is there a crew who goes around making snarky, rude comments on new posts? If so, I'll move along.
Old Mar 16, 2020 | 11:13 AM
john21031's Avatar
Never had this issue. I wouldn't force the lever when something is obviously restricting the movement.
From the video it is hard to determine what it is going on. Do you have the resistance at the flap itself? There could be a mouse nest or connection of debri. Touch very carefully everywhere with your hand to determine the issue. It's mechanical and should be simple.
lesterlai12
Aug 17, 2022 06:41 PM
Bombadillo
Apr 28, 2019 12:54 PM
AdamButlerTV
Jul 29, 2015 06:06 PM
Solscud007
Jul 15, 2013 04:36 PM
dezignpro04
Jun 28, 2009 03:51 AM
