Ignition ASSEMBLY 2010 Fit Sport
Old Mar 30, 2020 | 08:26 PM
Z907sport10's Avatar
Plz I NEED HELP REPLACING MY IGNITION ASSEMBLY. My original key was super glued in my ignition by crazy ex-boyfriend. I have recently purchased a new ignition assembly with a new key. I'm having a hard time getting the two bolts off the steering column. Any tips or suggestions are much appreciated.
from 2nd gen fit sport in Alaska
Old Mar 30, 2020 | 10:03 PM
Chris Adamson's Avatar
You should consult a Chilton Manuel. My library has free full online Chilton manuels that you can view and print at home. Sign into your local library as I bet yours will be the same😊
Make sure you disconnect your negative battery terminal first, and know where your radio Code is. It’s on a credit card looking thing in your Manuel. You’ll need it if you like listening to the radio.
Old Mar 30, 2020 | 10:27 PM
thank you for the info
how do I get that whole manual
Old Apr 1, 2020 | 07:09 AM
Black3sr's Avatar
Can you not get a wrench on them? Hard to tell from manual how much protrudes. Give them a bit of a whack with hammer and say screwdriver just enough to loosen the threads should help.
Glue his man parts to his thigh.
soboyle
May 24, 2020 04:03 PM
Iflooru
Aug 26, 2019 01:31 PM
EchoWars
Nov 7, 2017 08:44 AM
jeff_1986
Oct 30, 2011 06:26 PM
tubaman
Aug 31, 2006 03:01 PM
