GE Cylinder door lock cable connection
Old Apr 2, 2020 | 09:03 PM
Fitfreak888's Avatar
hello everyone, I would like to seek you guidance on where to connect the cable of the cylinder lock. Reason is whenever I use the key to open the door its not opening. I also saw from the inside that the cable from cylinder lock is disconnected. I would appreciate if we have a diagram or picture of the cable connection. Thanks in advance.
Old Apr 7, 2020 | 06:25 AM
Black3sr's Avatar
This help?
Old Apr 7, 2020 | 09:06 AM
Originally Posted by Black3sr
This help?
Almost. :-) thanks for your response.
I am able to source a picture. I was referring to the black cable connected to the actuator. I found out that my actuator from the driver side has no opening for the cable. Hence, I will replace it once the new once arrives. Thanks for your help.
Old Apr 7, 2020 | 10:41 PM
Found it
I found a picture on the internet and noticed that my door actuator on the driver side has no opening for the cable. I am just waiting for the new part to arrive then will replace it. Thanks for you response.
g fit
Dec 19, 2017 05:01 PM
Hondarian
Apr 24, 2016 05:29 AM
markakis3100
Mar 25, 2016 01:50 PM
cjmiller14
Jan 1, 2016 12:12 PM
NirraSiyapa
Sep 24, 2013 11:38 AM
