Steering noise- clunk
Old Apr 19, 2020 | 09:49 PM
dh7873's Avatar
2010 Sport, Automatic. When I have the car running and steering straight, I get a clunk noise when moving the wheel about 15 degrees from center to the left. I only get the noise on the left side. I get the sound when I move the wheel move to the left, then back to center and repeat. This is when the brakes are applied at a stop. I replaced the inner and outer tie rods. There was some play in the left inner. Now when hold the inner tie rod and have someone move the wheel from center to left, I can feel movement and hear the noise.
I am thinking I need to replace the steering rack/box. Has anyone had this issue?
You can click the google drive link below. I uploaded a video of the noise:
https://drive.google.com/file/d/13wV...ew?usp=sharing
File Type: mov
Old Apr 20, 2020 | 12:22 AM
fukenfit's Avatar
That’s exactly what I had. Check both inner and outer tie rods. If everything seems ok, take off the inner tie rod boot and look at the actual steering rod for play as you steer. I ended up going to a junkyard for a whole steering rack.
Old Apr 20, 2020 | 12:28 AM
dh7873's Avatar
I replaced inner and outer on both sides already. Think I’m going to grab one from
a yard like you did.
if you don’t mind me asking, how much did you spend on the part/labor?
Old Apr 20, 2020 | 07:25 AM
fukenfit's Avatar
I bought the rack for a 100 and I did the labor. It is straight forward and to be honest quite easy.
Old Apr 20, 2020 | 10:00 PM
dh7873's Avatar
When you removed the subframe, did you use an engine support fixture?
ive been reading about it. Basically remove the subframe and it’s right there.
i replaced inner tie rods last week and want to re use them with the used rack I bought. If I swap the inners while the racks are off the frame, do I need the inner tie rod tool? I wouldn’t think so because a wrench would work.
thanks for you help.
Old Apr 20, 2020 | 11:44 PM
fukenfit's Avatar
No. I just disconnected the steering from the rack and disconnected all electrical harness then dropped the subframe.
fujisawa
Jan 7, 2025 09:23 PM
p220sigman
Nov 29, 2015 10:56 PM
getrax
Nov 22, 2013 08:46 PM
chilow
Apr 24, 2012 10:00 PM
pokems23
Jun 30, 2007 01:56 PM
