Towing a 2009 Honda Fit 5-Speed - Pull Fuses???
Old Jun 19, 2020 | 02:18 PM
glenf's Avatar
The owner's manual says that for 'long distances' you must pull two fuses to keep the battery from discharging but no where does it give a definition of 'long distance'! I plan to tow my 2009 Sport behind my motorhome and would rather not fiddle with fuse removal. How far or how long can I tow it before the battery will significantly discharge??
Old Jun 19, 2020 | 05:14 PM
Red 05's Avatar
On a new battery you would be fine to go 10-14 days before needing to charge it.
Old Jun 20, 2020 | 11:19 AM
Mister Coffee's Avatar
@glenf: Can't you simply disconnect the negative lead on the battery, or am I missing something here?
Old Jun 20, 2020 | 12:09 PM
glenf's Avatar
Sure you can but then you need to reset the code on the radio/navigation or it won't work.
I did find that my ignition switch seems to have two different unlocked/accessory positions, the first of which does not operate the radio, etc. This may be the solution to my problem!
Old Jun 21, 2020 | 04:05 PM
glenf's Avatar
OK, now for an update - I have just determined that my ignition switch appears to have two ACC positions! The first one, after OFF, appears to unlock the steering but does not turn on the electrical circuits. The second one, after OFF, not only unlocks the steering, but also turns on the radio, cigarette lighter, etc. so if I leave the key in the first ACC while towing, I shouldn't have to remove any fuses, etc. Can anyone else please confirm this?? Sure would make life simpler!
Old Jun 28, 2020 | 08:37 AM
Black3sr's Avatar
\wrong. The battery is still connected so will drain after a period f non use. Just disconnect the neg lead.
So which two fuses do they recommend removing?
Old Jun 28, 2020 | 09:21 AM
glenf's Avatar
From page 239 of the 2009 Owner's Manual: "When towing your vehicle for long (not defined) periods, remove the 20A Accessory Socket and the 30A Radio fuses to reduce drain on battery. These fuses are located in the interior fuse box and are shown as number 13 and 61 below." No where do they define 'long periods'!
I have towed Toyotas for years and have never had a problem with the battery discharging so long as I turned the radio off prior to towing.
Unfortunately for Hondas, disconnecting the battery (or perhaps pulling the fuse) requires you to again enter the radio code every time that you reconnect. Not one of Honda's 'better ideas'!
Old Jun 28, 2020 | 05:42 PM
Black3sr's Avatar
Well it is not to difficult to enter 5 digits to reset radio. I just did mine.
Interesting my online manual skips page 239. But this is what I have in my shop manual.
Automatic Transmission ● Release the parking brake. ● Start the engine. ● Shift to D, then to N. ● Turn off the engine. ● Leave the ignition switch in ACCESSORY (I) so the steering wheel does not lock. ● Make sure the all accessories are turned off to minimize battery current draw. It is best to tow the vehicle no farther than 50 miles (80 km), and keep the vehicle speed below 35 mph (55 km/h).
This is for towing with all 4 wheels on ground
gaw401@aol.com
Jan 21, 2019 12:41 AM
Fit09Pete
Dec 8, 2017 10:58 PM
paullahey
Mar 16, 2015 09:17 AM
gypsysuzy
Sep 21, 2012 10:12 AM
FlaDan
Dec 31, 2009 08:13 AM
