Terrible noise from dash when a/c running
Old Sep 18, 2020 | 05:35 PM
Dougyfresh's Avatar
There’s a really bad rattling sound coming from the passenger side dash/glovebox when the a/c is running. Just recently started happening. Any ideas or advice would be appreciated.
its a 2009 Honda Fit Sport.
Thanks,
Doug
Old Sep 19, 2020 | 11:39 PM
ommegga's Avatar
Either the blower motor is going out or an object is stuck in there...
Old Sep 20, 2020 | 12:01 AM
Pyts's Avatar
Glovebox is super easy to remove, pinch and lower down. Likely culprit is blower motor. you'll be back by the cabin filter and can check that for buildup/obstruction as well as the shutter that opens and closes based on if you selected to draw air from inside or out. Can check out its pulley and cables for damage or disconnection.
Old Sep 20, 2020 | 04:20 AM
TheTickingGE8's Avatar
Check your freeon level if it’s whining like a kicked dog you prolly need some.
Old Oct 8, 2020 | 10:21 PM
dll932's Avatar
Thanks,
Doug
from time to time I end up with acorns in the top of the blower. This causes noise and vibration. It stops when I remove them.
Old Jan 5, 2021 | 05:14 PM
09Fitskies's Avatar
I was having AC problems in the summer but it went away
gfrobe
Feb 10, 2015 07:21 PM
cargirl2B
Jun 10, 2013 07:24 AM
benmunger
May 17, 2011 07:52 PM
daveymcgav
Apr 10, 2009 02:26 PM
DeadlyAcuraccy
Jan 25, 2008 08:12 AM
